Intel® Makers
9881 Discussions
"How to" Assembler Debugging Intel Galileo
NTöpf
Hey,
i´m trying to use the Galileo Board for some small educational assaembler programs.
The students should wirte there code on an Windows PC and then load it to the Galileo Board, where it will be executed.
During the execution the student should be able to check the values of the registers via the PC and executed there programm step by step.
This is my first "project" in this field and really dont have any idea how to do it. I´m missing the idea of how to connect to the galileo board and look inside the CPU registers.
I have already checked some other threads like those listed below, but it didn´t help very much.
/message/219985 https://communities.intel.com/message/219985
http://www.visualmasm.com/why-assembler.html Why Assembler - Visual MASM - The MASM IDE for Microsoft Macro Assembler
Does anyone know a solid "How To"-Guid that deals with this?
Diego_V_Intel
Hello Pete1987,
Unfortunately there isn't a guide about it. I checked the thread you pointed and it looks very useful. The same user that opened the thread was able to access the registers using Insight GUI: . Considering the fact that there aren't guides for this, the best option would be to try using Insight just as the other user did and check the documentation shared in that thread.
Diego.
Diego_V_Intel
Hello Pete1987,
Diego.
