Community
cancel
Showing results for
Search instead for
Did you mean:
PMuld2
New Contributor II
"illegal instruction" when accessing serial port
I wanted to play with the serial ports of an Intel Galileo Gen. 2.
I am using the SD card image with Node.js.
When I run my Node.js script, I get:
root@galileo:~/serialtest# node openport.js
Illegal instruction
Now, the script is simply opening the port and waiting for data:
var SerialPort = require("serialport").SerialPort;
var modem='/dev/ttyS0'; // or other ports
var serialPort = new SerialPort(modem, {
baudrate: 115200
}, false); // this is the openImmediately flag [default is true]
serialPort.open(function (error) {
if ( error ) {
console.log('failed to open: '+error);
} else {
console.log('open');
serialPort.on('data', function(data) {
console.log('data received: ' + data);
serialPort.write("ls\n", function(err, results) {
console.log('err ' + err);
console.log('results ' + results);
Pedro_M_Intel
Hello poseid,
Which library are you using? Did you remember to enable the serial port muxes. In case you didn't, you will find the instructions o how to do it in: .
Peter.
Carlos_M_Intel
Hi poseid,
Have you been able to use the Serial port of the board? Did you try with Peter's suggestion? You can also try to use the port with the http://iotdk.intel.com/docs/master/mraa/ MRAA library
Charlie
VOrti
Have you been able to do this? I got the same issue
