i had dump ref_os on intel joule board
im trying to edit sshd_config file but its showing that its only read only file.
and im trying to copy file from memory card is howing same
root@intel-5xx-64:~# [ 97.813429] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[ 97.837132] mmc1: tuning execution failed
[ 97.843712] mmcblk1: unknown error -5 sending read/write command, card status 0xc00900
[ 99.931489] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[ 99.952290] mmc1: tuning execution failed
[ 99.959339] mmcblk1: unknown error -5 sending read/write command, card status 0xc00900
[ 100.111659] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, falling back to fixed sampling clock
[ 100.132270] mmc1: tuning execution failed
[ 100.138608] mmc1: tried to reset card, got error -5
[ 100.145855] blk_update_request: I/O error, dev mmcblk1, sector 12982712
[ 100.155126] blk_update_request: I/O error, dev mmcblk1, sector 12982720
[ 100.164298] blk_update_request: I/O error, dev mmcblk1, sector 12982728
[ 100.173424] blk_update_request: I/O error, dev mmcblk1, sector 12982736
[ 100.182727] blk_update_request: I/O error, dev mmcblk1, sector 12982744
[ 100.191990] Aborting journal on device mmcblk1p3-8.
[ 101.036040] EXT4-fs error (device mmcblk1p3): ext4_journal_check_start:56: Detected aborted journal
[ 101.048033] EXT4-fs (mmcblk1p3): Remounting filesystem read-only
Hi Umesh@pro3,
Thanks for your interest in the Intel® Joule™ Platform.
From your reply: "im trying to edit sshd_config file but its showing that its only read only file". I interpret that you are modifying a file, but you are having permission issues. If this is correct have you try the command chmod +x file-name? If I'm not interpreting right your issue, could you be so kind to elaborate a little more, so that I can provide you the proper guidance for your issue.
I will be waiting for your reply, have a nice day!
-Jose P.
Hi Umesh@pro3,
Were you able to modify the permission on your read only file? Please let me know in order to assist you.
Have a nice day!
-Jose P.
i have build Ref_Os for intel joule board (base image)
Referred steps given at https://github.com/01org/ref-os-iot GitHub - 01org/ref-os-iot: This is the official distribution of the Intel(R) Reference Operating System for the Internet…
instead of bitbake full-image
i build
bitbake base-image
and follow the same procedure for making uSD as bootable device and boot from uSD card.
i have boot it from uSD card and changed boot order to eMMC.
now i want to send a application file to board through scp. its not allowing me to send file through scp ,it requires to change "# PermitRootLogin yes" from vi /etc/ssh/sshd_config but,
it says that '/etc/ssh/sshd_config' Read-only file system.
if im trying to change the permissions by using "chmod" then
root@intel-5xx-64:~# chmod 777 /etc/ssh/sshd_config
chmod: /etc/ssh/sshd_config: Read-only file system
if im trying to copy file from pendrive it says can't create file Read-only file system.
even i tried to remount using sudo mount -o remount,rw /
it shows-
[ 1566.878042] EXT4-fs error (device mmcblk1p3): ext4_remount:4695: Abort forced by user
mount: cannot remount /dev/root read-write, is write-protected
i tried to change password but it says that
root@intel-5xx-64:~# passwd
New password:
Retype new password:
passwd: Authentication token manipulation error
passwd: password unchanged
before this log come im able to change in fs-
<p style="font-family: intel-clear, ari...- Mark as New
Hi Umesh@pro3,
Thanks for explaining your issue in such a detailed manner!
Actually, I was able to reproduce your issue by mounting a USB stick on my Joule, then I was able to copy the file inside it. Please see the image below, so that you can understand better what I'm trying to explain.
You should know that I was using the full image from here https://github.com/01org/ref-os-iot GitHub - 01org/ref-os-iot: This is the official distribution of the Intel(R) Reference Operating System for the Internet… , I will start building the base image, so that I can perform the same experiment with this image.
Have a nice day!
-Jose P.
im sending boot log ------>
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.41-yocto-standard (root123@procubed) (gcc version 5.4.0 (GCC) ) # 1 SMP PREEMPT Tue May 2 17:50:15 IST 2017
[ 0.000000] Command line: rootwait console=tty0 console=ttyS2,115200 video=efifb maxcpus=4 noxsave reboot=efi kmemleak=off fsck.mode=skip panic=5 no-ima security=none ro root=PARTUUID=12345678-9abc-def0-
[ 0.000000] x86/fpu: xstate_offset[3]: 960, xstate_sizes[3]: 64
[ 0.000000] x86/fpu: xstate_offset[4]: 1024, xstate_sizes[4]: 64
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x01: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x02: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x08: 'MPX bounds registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x10: 'MPX CSR'
[ 0.000000] x86/fpu: Enabled xstate features 0x1b, context size is 1088 bytes, using 'standard' format.
[ 0.000000] x86/fpu: Using 'eager' FPU context switches.
[ 0.000000] e820: BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x0000000000057fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000000058000-0x0000000000058fff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000059000-0x000000000009dfff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009e000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000000fffffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000010000000-0x0000000012550fff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000012551000-0x0000000078982fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000078983000-0x0000000078dabfff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000078dac000-0x0000000078e0bfff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x0000000078e0c000-0x0000000078e4bfff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x0000000078e4c000-0x0000000079df2fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000079df3000-0x0000000079df3fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x0000000079df4000-0x0000000079e1dfff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000079e1e000-0x000000007b3fffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000007b400000-0x000000007fffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000e3ffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed01000-0x00000000fed01fff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000017fffffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] efi: EFI v2.50 by EDK II
[ 0.000000] efi: ACPI=0x78e4b000 ACPI 2.0=0x78e4b014 ESRT=0x78d80000 SMBIOS=0x78b63000 SMBIOS 3.0=0x78b61000 PROP=0x790843d0
[ 0.000000] efi: requested map not found.
[ 0.000000] esrt: ESRT header is not in the memory map.
[ 0.000000] SMBIOS 3.0.0 present.
[ 0.000000] e820: last_pfn = 0x180000 max_arch_pfn = 0x400000000
[ 0.000000] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WC UC- WT
[ 0.000000] e820: last_pfn = 0x7b400 max_arch_pfn = 0x400000000
[ 0.000000] Scanning 1 areas for low memory corruption
[ 0.000000] Using GB pages for direct mapping
[ 0.000000] RAMDISK: [mem 0x783b6000-0x78982fff]
[ 0.000000] ACPI: Early table checksum verification disabled
[ 0.000000] ACPI: RSDP 0x0000000078E4B014 000024 (v02 INTEL )
[ 0.000000] ACPI: XSDT 0x0000000078E28188 0000F4 (v01 INTEL EDK2 00000003 BRXT 01000013)
[ 0.000000] ACPI: FACP 0x0000000078E42000 00010C (v05 INTEL EDK2 00000003 BRXT 0100000D)
[ 0.000000] ACPI: DSDT 0x0000000078E36000 007082 (v02 INTEL EDK2 00000003 BRXT 0100000D)
[ 0.000000] ACPI: FACS 0x0000000078E09000 000040
[ 0.000000] ACPI: UEFI 0x0000000078E0B000 000042 (v01 INTEL EDK2 00000002 BRXT 01000013)
[ 0.000000] ACPI: DBG2 0x0000000078E49000 000072 (v00 INTEL EDK2 00000003 BRXT 0100000D)
[ 0.000000] ACPI: HPET 0x0000000078E47000 000038 (v01 INTEL EDK2 00000003 BRXT 0100000D)
[ 0.000000] ACPI: LPIT 0x0000000078E46000 00005C (v01 INTEL EDK2 00000003 BRXT 0100000D)
[ 0.000000] ACPI: APIC 0x0000000078E45000 000084 (v03 INTEL EDK2 00000003 BRXT 0100000D)
[ 0.000000] ACPI: MCFG 0x0000000078E44000 00003C (v01 INTEL EDK2 00000003 BRXT 0100000D)
[ 0.000000] ACPI: NPKT 0x0000000078E43000 000065 (v01 INTEL EDK2 00000003 BRXT 0100000D)
[ 0.000000] ACPI: PRAM 0x0000000078E41000 000030 (v01 INTEL EDK2 00000003 BRXT 0100000D)
[ 0.000000] ACPI: SSDT 0x0000000078E3E000 002769 (v02 INTEL DptfTab 00000003 BRXT 0100000D)
[ 0.000000] ACPI: SSDT 0x0000000078E35000 000A5D (v02 INTEL RVPRtd3 00000003 BRXT 0100000D)
[ 0.000000] ACPI: SSDT 0x0000000078E34000 00023E (v02 INTEL UsbCTabl 00000003 BRXT 0100000D)
[ 0.000000] ACPI: SSDT 0x0000000078E30000 0036A8 (v01 Intel_ Platform 00001000 INTL 20150818)
[ 0.000000] ACPI: SSDT 0x0000000078E2F000 0003CA (v01 INTEL EprmSdt0 00001000 INTL 20150818)
[ 0.000000] ACPI: EM_1 0x0000000078E2D000 000029 (v00 INTEL OEM1 00000005 INTL 0100000D)
[ 0.000000] ACPI: OEM1 0x0000000078E2C000 000040 (v01 INTEL ENRGYMGT 00000005 INTL 0100000D)
[ 0.000000] ACPI: PIDV 0x0000000078E2B000 0000DC (v02 00000002 BRXT 0100000D)
[ 0.000000] ACPI: RSCI 0x0000000078E2A000 000030 (v02 INTEL BOOTSRC 00000001 BRXT 0100000D)
[ 0.000000] ACPI: SSDT 0x0000000078E2E000 0004A5 (v02 PmRef Cpu0Ist 00003000 INTL 20150818)
[ 0.000000] ACPI: SSDT 0x0000000078E29000 00072B (v02 CpuRef CpuSsdt 00003000 INTL 20150818)
[ 0.000000] ACPI: SSDT 0x0000000078E4A000 00032D (v02 PmRef Cpu0Tst 00003000 INTL 20150818)
[ 0.000000] ACPI: SSDT 0x0000000078E27000 00017C (v02 PmRef ApTst 00003000 INTL 20150818)
[ 0.000000] ACPI: SSDT 0x0000000078E24000 002865 (v02 SaSsdt SaSsdt 00003000 INTL 20150818)
[ 0.000000] ACPI: FPDT 0x0000000078E23000 000044 (v01 INTEL EDK2 00000002 BRXT 01000013)
[ 0.000000] ACPI: WDAT 0x0000000078E48000 000104 (v01 00000000 00000000)
[ 0.000000] ACPI: NHLT 0x0000000078E21000 001CB1 (v00 INTEL EDK2 00000002 BRXT 01000013)
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.000000] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x000000017fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000001000-0x0000000000057fff]
[ 0.000000] node 0: [mem 0x0000000000059000-0x000000000009dfff]
[ 0.000000] node 0: [mem 0x0000000000100000-0x000000000fffffff]
[ 0.000000] node 0: [mem 0x0000000012551000-0x0000000078982fff]
[ 0.000000] node 0: [mem 0x0000000078e4c000-0x0000000079df2fff]
[ 0.000000] node 0: [mem 0x0000000079e1e000-0x000000007b3fffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000017fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000017fffffff]
[ 0.000000] Reserving Intel graphics stolen memory at 0x7c000000-0x7fffffff
[ 0.000000] ACPI: PM-Timer IO Port: 0x408
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high level lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] high level lint[0x1])
[ 0.000000] ACPI: LAPIC...
Hi Umesh@pro3,
Thanks for sharing this! As soon as we have some useful information we will get back to you.
Have a nice day!
-Jose P.
Hi Umesh@pro3,
Thanks for your patience.
I was able to build the base-image and flash it on my Joule, then I perform the same experiment of mounting a USB and copying a file on it. Unfortunately, I didn't encounter any errors, please see the image below.
Are you sure that you are mounting correctly, your USB stick?
-Jose P.
one more thing when im installing os and while working on board this log msg interrupts .....this msg frequently comes ......
and if im removed sd card from board after install os on eMMC then this msg continuously comes and os was not boot............
and im trying to update to new bios ,board is not going in DNX boot...???
[ 559.987957] mmc1: Timeout waiting for hardware interrupt.
[ 559.996017] ------------[ cut here ]------------
[ 560.001183] WARNING: CPU: 1 PID: 0 at /home/root123/work/ref-os-iot/build/tmp-glibc/work-shared/int)
[ 560.019657] Modules linked in:
[ 560.023072] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G W 4.4.41-yocto-standard # 1
[ 560.032509] Hardware name: Intel Corp. Broxton M/SDS, BIOS GTPP161A.X64.0143.B30.1611152208 11/15/26
[ 560.042918] 0000000000000000 ffff88017fc83d30 ffffffff813c545b 0000000000000000
[ 560.051193] ffffffff81b72bf8 ffff88017fc83d68 ffffffff81073db2 ffff88000006a500
[ 560.059473] ffff88007ac2e930 0000000000000246 ffff88007ac2e970 ffff88000006a500
[ 560.067760] Call Trace:
[ 560.070490] [] dump_stack+0x4d/0x72
[ 560.076927] [] warn_slowpath_common+0x82/0xc0
[ 560.083641] [] warn_slowpath_null+0x1a/0x20
[ 560.090160] [] sdhci_send_command+0x729/0xc70
[ 560.096875] [] ? __const_udelay+0x27/0x30
[ 560.103202] [] ? sdhci_reset+0x59/0xc0
[ 560.109236] [] sdhci_finish_data+0xd8/0x3a0
[ 560.115756] [] ? sdhci_finish_data+0x3a0/0x3a0
[ 560.122566] [] sdhci_timeout_timer+0x7b/0xc0
[ 560.129185] [] call_timer_fn+0x3e/0x170
[ 560.135315] [] ? sdhci_finish_data+0x3a0/0x3a0
[ 560.142126] [] run_timer_softirq+0x204/0x2a0
[ 560.148742] [] __do_softirq+0x9f/0x2e0
[ 560.154776] [] irq_exit+0x9d/0xa0
[ 560.160326] [] smp_apic_timer_interrupt+0x42/0x50
[ 560.167427] [] apic_timer_interrupt+0x7f/0x90
[ 560.174140] [] ? cpuidle_enter_state+0x123/0x2f0
[ 560.181832] [] ? cpuidle_enter_state+0x10d/0x2f0
[ 560.188836] [] cpuidle_enter+0x17/0x20
[ 560.194869] [] call_cpuidle+0x32/0x60
[ 560.200806] [] ? cpuidle_select+0x13/0x20
[ 560.207129] [] cpu_startup_entry+0x263/0x320
[ 560.213747] [] start_secondary+0x105/0x130
[ 560.220170] ---[ end trace d76bef16ac72b5e7 ]---
[ 560.227658] mmcblk1: error -110 sending stop command, original cmd response 0x0, card status 0xc0090
[ 560.238078] mmcblk1: error -110 transferring data, sector 13050704, nr 256, cmd response 0x0, card 0
[ 560.377772] sdhci: Timeout waiting for Buffer Read Ready interrupt during tuning procedure, fallingk
[ 560.394788] mmc1: tuning execution failed
[ 560.399278] mmc1: tried to reset card, got error -5
[ 560.404734] blk_update_request: 118 callbacks suppressed
[ 560.410676] blk_update_request: I/O error, dev mmcblk1, sector 13050704
[ 560.418079] buffer_io_error: 118 callbacks suppressed
[ 560.423729] Buffer I/O error on dev mmcblk1p3, logical block 6462888, lost async page write
[ 560.433081] blk_update_request: I/O error, dev mmcblk1, sector 13050706
[ 560.440483] Buffer I/O error on dev mmcblk1p3, logical block 6462889, lost async page write
[ 560.449830] blk_update_request: I/O error, dev mmcblk1, sector 13050708
[ 560.457230] Buffer I/O error on dev mmcblk1p3, logical block 6462890, lost async page write
[ 560.466580] blk_update_request: I/O error, dev mmcblk1, sector 13050710
[ 560.473979] Buffer I/O error on dev mmcblk1p3, logical block 6462891, lost async page write
[ 560.483333] blk_update_request: I/O error, dev mmcblk1, sector 13050712
[ 560.490733] Buffer I/O error on dev mmcblk1p3, logical block 6462892, lost async page write
[ 560.500080] blk_update_request: I/O error, dev mmcblk1, sector 13050714
[ 560.507481] Buffer I/O error on dev mmcblk1p3, logical block 6462893, lost async page write
[ 560.516827] blk_update_request: I/O error, dev mmcblk1, sector 13050716
[ 560.524224] Buffer I/O error on dev mmcblk1p3, logical block 6462894, lost async page write
[ 560.533570] blk_update_request: I/O error, dev mmcblk1, sector 13050718
[ 560.540971] Buffer I/O error on dev mmcblk1p3, logical block 6462895, lost async page write
[ 560.550320] blk_update_request: I/O error, dev mmcblk1, sector 13050720
[ 560.557721] Buffer I/O error on dev mmcblk1p3, logical block 6462896, lost async page write
[ 560.567068] blk_update_request: I/O error, dev mmcblk1, sector 13050722
[ 560.574464] Buffer I/O error on dev mmcblk1p3, logical block 6462897, lost async page write
[ 560.601061] mmcblk1: timed out sending r/w cmd command, card status 0x800900
[ 560.611049] mmcblk1: timed out sending r/w cmd command, card status 0x800900
Hi Umesh@pro3,
I'm a little confused, when you say "one more thing when im installing os and while working on board this log msg interrupts". Which OS are you installing? From your first reply I understood that you were using the Ref OS IoT base-image, I'm I right?
Now, regarding the BIOS update, are you following the steps in this guide https://software.intel.com/en-us/flashing-the-bios-on-joule IoT ? If you're, please be sure that you are using a Type-A to Type-C USB cable.
-Jose P.
yes, im installing same Ref_os, while installing that above msg is comes frequently ,sometimes os not even installed msg come [R]rebbot/[S]shell ?
im not worried about bios setup ,i just neet help to resolve that read-only issue.
Hi Umesh@pro3,
If you are having problems installing the Ref OS IoT, I would encourage to download the latest Joule image from https://download.01.org/ref-os-iot/releases/1704/5xx/ Index of /ref-os-iot/releases/1704/5xx and create a bootable device by following these instructions https://software.intel.com/en-us/node/721472 IoT . Then you can flash your image by following these guides:
- https://software.intel.com/en-us/node/721477 IoT
- https://software.intel.com/en-us/node/721470 IoT
Now, regarding the "read-only" issue, I would encourage to follow the steps that I provided here . I have summarized the steps in here:
1) Navigate to media: cd media (Be sure you are on your home directory, if you aren't use the command cd ~ )
2) Create a directory call "usb": mkdir usb.
3) Mount your device: mount dev/sdx /media/usb (Where sdx is the name of your USB drive).
4) Copy the file: cp media/usb/name-of-the-file /path-where-you-want-to-copy
Have a nice day!
-Jose P.
i know these steps for copying file from usb or pen-drive. im facing read-only file system while copying file.... using
CP cmd ,and regarding to pre-build os its having same issue with https://download.01.org/ref-os-iot/releases/1704/5xx/ Index of /ref-os-iot/releases/1703/5xx and im even tried with ostro-os. same issue with this os also.
now im using Ref_os ....!!
Hi Umesh@pro3,
I understand that there are two issues, one related to copy a file from your USB and the other related to the image that you are using.
We will investigate more about your permission error, in the meantime could you be so kind to format your USB drive and try again. Also, I would encourage to change the USB drive if this doesn't work.
Finally, I would like to know what you meant when you said "now im using Ref_os ....!!", does this mean that your image error was fixed with the new release? If it wasn't I would encourage you to download the newer version of the Ref OS IoT from here https://download.01.org/ref-os-iot/releases/1704/5xx/ Index of /ref-os-iot/releases/1704/5xx .
Have a nice day!
-Jose P.
currently im using ref-os ,and facing issue on ref_os ,but also im tried on ostro-os, thats why i mention ," im using Ref_os ....!! "
Hi Umesh@pro3,
Thanks for explaining us what image you are using!
Now we are following this guide https://software.intel.com/en-us/node/721524 IoT , in order to setup the SSH connection. We did not have issues editing the file /etc/ssh/sshd_config, we would encourage to follow these steps:
1) In Joule console, run the command vi /etc/ssh/sshd_config. This will open the Vi editor.
2) Find the line "# PermitRobotLogin yes" and uncomment it. You will have to press the "i" key to enter in edition mode in the Vi editor.
3) Save the file.
4) Then, you should get the message "/etc/ssh/sshd_config" 133L 3629C written" which confirms that you just edited the file. If you want to double check, then run the command cat /etc/ssh/sshd_config.
By the way here is an image of the steps that we follow:
We hope you find this information useful, have a nice day!
-Jose P.
thaks for reply ,
im just try to install new released 1704 full-image(pre-build).
im sending a log .........
1st time when im try to install it on eMMC-->>
Board Name = Joule DVT2
MRC REVISION ID 1.52.27
MMRC REVISION ID 1.09
BIOS ID = GTPP161A.X64.0143.B30.1611152208
Start showing progress bar...
- Press any key to stop it!
- Press F2 or b to enter BIOS setup.
- Press F5 or d to enter Device Manager.
- Press F7 or m to enter Boot Manager.
- Press F9 or o to enter Boot Order.
...Zzz...
Showing progress bar...Remaining 5 second!
▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒Ŀ
▒ Boot Maintenance Manager
Boot Options Modify system boot options
Driver Options
Console Options
Boot From File
Set Boot Next Value
Set Time Out Value
Reset System
▒ =Move Highlight //=Select /=Exit
Broxton M
Intel(R) Atom(TM) Processor T5700 @ 1.70GHz 1.70 GHz
GTPP161A.X64.0143.B30.1611152208 4096 MB RAM
Continue This selection will direct
Select Language the system to continue to
Boot Manager booting process
Device Manager
[ 0.000000] Linux version 4.4.41-yocto-standard (@tmsbuild023) (gcc version 6.3.0 (GCC) ) # 1 SMP PREEMPT Wed Apr 19 17:01:01 EEST 2017
[ 0.000000] Command line: rootwait console=tty0 console=ttyS2,115200 video=efifb maxcpus=4 noxsave reboot=efi kmemleak=off panic=5 no-ima security=none fsck.mode=skip root=PARTUUID=12345678-9abc-def0-0fed-cba987654321 rootfstype=ext4 installer video=efifb maxcpus=4 reboot=efi kmemleak=off console=tty0 console=ttyS2,115200
[ 0.000000]
[ 0.000000] e820: last_pfn = 0x180000 max_arch_pfn = ...
Hi Umesh@pro3,
Looking at your log it seems like there is an installation error when you are flashing the image to your Joule, please see the images below:
This is your log:
This how your log should look if your installation was successful:
Please be sure that you are following the instructions to create a bootable device https://software.intel.com/en-us/node/721472 IoT and the guides to flash the image to the Joule:
If you still encounter the same issue, please try to change your USB drive.
We will be waiting for your results, have a nice day!
-Jose P.
Hi Umesh@pro3,
Were you able to flash the image correctly into the Joule? Please let me know in order to assist you.
-Jose P.
Hi Umesh@pro3,
I'm sorry to hear that the issue persists. Reviewing your BIOS logs we realize that you are using the BIOS 161, the Ref OS IoT 1704 is only compatible with 1F1 https://download.01.org/ref-os-iot/releases/1704/Ref-OS-IoT-1704-ReadMe.txt https://download.01.org/ref-os-iot/releases/1704/Ref-OS-IoT-1704-ReadMe.txt . Please follow these steps https://software.intel.com/en-us/flashing-the-bios-on-joule IoT in order to update your BIOS.
If this doesn't work, could you be so kind to attach some screenshots of your errors?
-Jose P.
