Intel® Makers
Intel® Edison, Intel® Joule™, Intel® Curie™, Intel® Galileo
Welcome - This is a Peer-to-Peer Forum only. Intel has discontinued these products but you may find support from other customers on this Forum
9876 Discussions
reboot instead of poweroff when executing command "poweroff" on Edison
hston
New Contributor II
I found a problem, when I execute command "poweroff" on Edison with breakout, the target will reboot instead of poweroff, the OS image is edison-image-ww18-15 which downloaded from the Intel website. How can I fix the problem? Thanks!
Rock
Sergio_A_Intel
If you want to shut down your board instead of rebooting you can run the command shutdown now.This worked for me using:
root@Alvarado:~# configure_edison --version
159
Sergio
Sergio_A_Intel
159
Sergio
