I found a problem, when I execute command "poweroff" on Edison with breakout, the target will reboot instead of poweroff, the OS image is edison-image-ww18-15 which downloaded from the Intel website. How can I fix the problem? Thanks!
Rock
If you want to shut down your board instead of rebooting you can run the command shutdown now.This worked for me using:
root@Alvarado:~# configure_edison --version
159
Sergio
159
Sergio
