Community
cancel
Showing results for
Search instead for
Did you mean:
PPhil4
running valgrind
I'm running the 20160606 image from the Intel web site.
I did:
opkg install valgrind
and it installed: libc6-dbg and valgrind
When I run valgrind, I get the following:
valgrind: Fatal error at startup: a function redirection
valgrind: which is mandatory for this platform-tool combination
valgrind: cannot be set up. Details of the redirection are:
valgrind:
valgrind: A must-be-redirected function
valgrind: whose name matches the pattern: strlen
valgrind: in an object with soname matching: ld-linux.so.2
valgrind: was not found whilst processing
valgrind: symbols from the object with soname: ld-linux.so.2
valgrind:
valgrind: Possible fixes: (1, short term): install glibc's debuginfo
valgrind: package on this machine. (2, longer term): ask the packagers
valgrind: for your Linux distribution to please in future ship a non-
valgrind: stripped ld.so (or whatever the dynamic linker .so is called)
valgrind: that exports the above-named function using the standard
valgrind: calling conventions for this platform. The package you need
valgrind: to install for fix (1) is called
valgrind:
valgrind: On Debian, Ubuntu: libc6-dbg
valgrind: On SuSE, openSuSE, Fedora, RHEL: glibc-debuginfo
valgrind:
valgrind: Cannot continue -- exiting now. Sorry.
just to check that libc6-dbg is installed, I did:
opkg install libc6-dbg
and it replied:
Package libc6-dbg (2.20-r0) installed in root is up to date.
Any ideas on how to get valgrind to run?
Community Manager
Exactly what steps you did to get that output? I tried installing valgrind but didn't have that output.
The commands I ran were:
opkg install valgrind opkg install libc6-dbg
-Sergio
PPhil4
I did:
It reported installing libc6-dbg then installing valgrind. I then did:
valgrind myprog
And it generated the output I submitted.
If I run "valgrind --help" it runs successfully.
Community Manager
What are the contents of myprog, what kind of file is it? Valgrind is typically used like valgrind program args. This runs program under valgrind using the mem-check tool. What tool are you using?
Take a look at http://valgrind.org/docs/manual/quick-start.html http://valgrind.org/docs/manual/quick-start.html for more information.
-Sergio
PPhil4
Myprog is a C++ program compiled with GCC. I was running the memcheck tool.
I'm familiar with valgrind, having run it on other systems.
Community Manager
I'd like to test this behavior. Can you share the Myprog code and the GCC command you used to compile? Additionally, from which repository are you fetching the valgrind package?
-Sergio
Community Manager
Do you still need help with this thread, were you able to run valgrind?
-Sergio
PPhil4
Sorry for not getting back to you sooner, I was on a sort-of vacation.
I can repeat the problem with the following program:
# include
int main()
printf("Hello world\n");
return 0;
compiled with:
gcc hello.c -o hello
and run with:
valgrind ./hello
-phil
Community Manager
Hi phil.w.howard,
I ran the same steps as you and got the same fatal error message of your first post. I'll investigate further on this case and provide a suggestion soon.
-Sergio
ggreg6
Hi Sergio, I too am having this problem. This link seems to explain why it is having issues, but does not seem to correspond to the installation on the Edison.
http://www.64k-tec.de/2010/10/using-suppression-files-with-valgrind/ http://www.64k-tec.de/2010/10/using-suppression-files-with-valgrind/
I am running the same image as phil.w.howard, and have also verified that gbd and libc6-dbg are the latest version available.
Any help would be greatly appreciated.
Community Manager
Hi GDriscoll
We reproduced the issue and ran into the same issue as you and @ phil.w.howard. We've reported this situation to the proper team but there's no fix at the moment. We're working to see if it's possible for valgrind to work on future software releases. Thank you for your understanding.
-Sergio
Community Manager
We've found a workaround to use valgrind. The workaround is to reinstall libc6 (opkg install libc6 --force-reinstall)
This looks like a mismatch in the lD release/debug versions. The Edison image comes with the libc6 package installed, valgrind installs libc6-dbg as a dependency. For some reason, even though they are the same version they're causing a conflict. Possibly since the libc6 ipk's have a different date than the .so's in the Edison image.
-Sergio
ggreg6
Hi Sergio, Thank you for the workaround. This is working now!
-Greg
MPapi
Hi Phil,
I was able to run background by installing all of the "optional" clibxxx.ipk modules from Alex's repository.
Hope this helps - Mario.
Community Manager
Hi Mario,
Thank you for providing a workaround for this. Hopefully this will be useful for other users in the community who are trying to use valgrind.
-Sergio
Community Manager
Thank you for letting us know this suggestion worked. If you have other questions don't hesitate to open a new thread to receive help from the community.
-Sergio
