Hi Sir:
we had build the D2000 rev2 board .use the ISSM sample code.
1. for the hellow_world how could i see the message ?
2. for the PWM we had build sample code but can't update target ROM... (show error)
Hi tabchiou,
There is actually an inbuilt serial terminal in the Intel System Studio 2016 for Microcontroller. It has a getting_started.htm guide in the docs folder under your install directory which normally will be C:\IntelSWTools\ISSM_2016.0.027\docs.
In that particular document there is a section explaining how you can get the serial output on terminal.
Thanks !
Vincent
Hi tabchiou,
Thanks !
Vincent
Hi tabchiou,
Regarding your second question, that is a known issue take a look into /community/tech/microcontrollers/blog/2016/04/06/limitations-and-known-issues-in-intel-system-studio-2016-for-microcontroller?et=watches.email.blog this site. The use of PWM0 multiplexes the JTAG pins that prevent flashing the board. I suggest you to try the recovery method mentioned in the previous link. Let us know if the recovery helps.
JPMontero_Intel
