Community
cancel
Showing results for
Search instead for
Did you mean:
akham2
sdp_record_register function doesn't work
Jump to solution
hi,
I have been using bluez library included by Intel Edison.My problem is when I try to register a service using sdp_record_register, it blocks the sketch and doesn't make any progress. In the following or attached code you can see that I have put a print statement after the function but it doesn't print. Any suggestions please?
regards,
Abdulrahman
akham2
Finally I found the solution. The problem was not in the code. I just needed to modify bluetooth.service file ( I added -C after bluetoothd) and boom it worked.
Thanks for your help I really appreciate it.
akham2
the problem in register_service() function
the code:
# include
# include
# include
# include
# include
# include
# include
# include
# include
# include
# include
//# define ADD_ANY (&(bdaddr_t) {{0, 0, 0, 0, 0, 0}})
//# define ADD_ALL (&(bdaddr_t) {{0xff, 0xff, 0xff, 0xff, 0xff, 0xff}})
//# define ADD_LOCAL (&(bdaddr_t) {{0, 0, 0, 0xff, 0xff, 0xff}})
LiquidCrystal lcd(8,9,4,5,6,7);
char buf[1024];
char addr[19];
char name[248];
bdaddr_t Add_Any = {{0, 0, 0, 0, 0, 0}};
bdaddr_t Add_Loc = {{0, 0, 0, 0xff, 0xff, 0xff}};
bdaddr_t *ptrAny;
bdaddr_t *ptrLoc;
struct sockaddr_rc loc_addr, rem_addr;
int s, client, bytes_read;
int bndError, listError;
socklen_t opt;
void setup() {
lcd.begin(16, 2);
Serial.begin(9600);
lcd.print("Welcome");
delay(3000);
ptrAny = &Add_Any;
ptrLoc = &Add_Loc;
register_service();
//opt = sizeof(rem_addr);
addr[19] = { 0 };
name[248] = { 0 };
//loc_addr = { 0 };
//rem_addr = { 0 };
buf[1024] = { 0 };
// allocate socket
s = socket(AF_BLUETOOTH, SOCK_STREAM, BTPROTO_RFCOMM);
// bind socket to port 1 of the first available
// local bluetooth adapter
loc_addr.rc_family = AF_BLUETOOTH;
loc_addr.rc_bdaddr = *ptrAny;
loc_addr.rc_channel = (uint8_t) 11;
bndError = bind(s, (struct sockaddr *)&loc_addr, sizeof(loc_addr));
// put socket into listening mode
listError = listen(s, 1);
Serial.println("setup done");
Serial.println("Socket ");
Serial.print(s);
Serial.println("bind ");
Serial.print(bndError);
Serial.println("listen ");
Serial.print(listError);
lcd.clear();
lcd.print("done setup");
delay(10000);
void loop() {
lcd.clear();
Serial.println("done setup");
// accept one connection
client = accept(s, (struct sockaddr *)&rem_addr, &opt);
Serial.println("accept ");
Serial.print(client);
if(client > 0){
ba2str( &rem_addr.rc_bdaddr, buf );
lcd.clear();
lcd.setCursor(0,0);
lcd.print("con request from");
lcd.setCursor(0,1);
lcd.print(buf);
delay(2000);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("conected");
delay(2000);
while(1){
lcd.clear();
lcd.setCursor(0,0);
lcd.print("waitng for");
lcd.setCursor(0,1);
lcd.print("command");
delay(1000);
memset(buf, 0, sizeof(buf));
// read data from the client
bytes_read = read(client, buf, sizeof(buf));
Serial.println("read ");
Serial.print(bytes_read);
if( bytes_read > 0 ) {
lcd.clear();
lcd.setCursor(0,0);
lcd.print(buf);
delay(2000);
// setup and register service 77FE183EA9D911E5ACA9C2AE1D5D46B0
//sdp_session_t *register_service()
void register_service(){
//Serial.println("hi ");
uint32_t service_uuid_int[] = { 0, 0, 0, 0x77FE183EA9D911E5ACA9C2AE1D5D46B0};
uint8_t rfcomm_channel = 11;
const char *service_name = "Edison";
const char *service_dsc = "An experiment about bluetooth";
const char *service_prov = "Abdul";
uuid_t root_uuid, l2cap_uuid, rfcomm_uuid, svc_uuid;
sdp_list_t *l2cap_list = 0,
*rfcomm_list = 0,
*root_list = 0,
*proto_list = 0,
*access_proto_list = 0;
sdp_data_t *channel = 0, *psm = 0;
sdp_record_t *record = sdp_record_alloc();
// set the general service ID
sdp_uuid128_create( &svc_uuid, &service_uuid_int );
sdp_set_service_id( record, svc_uuid );
// make the service record publicly browsable
sdp_uuid16_create(&root_uuid, PUBLIC_BROWSE_GROUP);
root_list = sdp_list_append(0, &root_uuid);
sdp_set_browse_groups( record, root_list );
// set l2cap information
sdp_uuid16_create(&l2cap_uuid, L2CAP_UUID);
l2cap_list = sdp_list_append( 0, &l2cap_uuid );
proto_list = sdp_list_append( 0, l2cap_list );
// set rfcomm information
sdp_uuid16_create(&rfcomm_uuid, RFCOMM_UUID);
channel = sdp_data_alloc(SDP_UINT8, &rfcomm_channel);
rfcomm_list = sdp_list_append( 0, &rfcomm_uuid );
sdp_list_append( rfcomm_list, channel );
sdp_list_append( proto_list, rfcomm_list );
// attach protocol information to service record
access_proto_list = sdp_list_append( 0, proto_list );
sdp_set_access_protos( record, access_proto_list );
// set the name, provider, and description
sdp_set_info_attr(record, service_name, service_prov, service_dsc);
int err = 0;
sdp_session_t *session = 0;
// connect to the local SDP server, register the service record, and
// disconnect
session = sdp_connect( ptrAny, ptrLoc, SDP_RETRY_IF_BUSY );
err = sdp_record_register(session, record, 0);
lcd.clear();
lcd.print("Stop here");
// cleanup
sdp_data_free( channel );
sdp_list_free( l2cap_list, 0 );
sdp_list_free( rfcomm_list, 0 );
sdp_list_free( root_list, 0 );
sdp_list_free( access_proto_list, 0 );
//return session;
/*0x77FE183EA9D911E5ACA9C2AE1D5D46B0
0x71ECA406A9D911E5B96AB3AE1D5D46B0*/
Pedro_M_Intel
Hello ENG_akhamis,
I found the following discussion on a quick search on Google, I believe it might help you, it looks like a very similar issue to yours.
http://sourceforge.net/p/bluez/mailman/message/14322925/ BlueZ / Mailing Lists
I'm not very familiar with this specific method of BlueZ, and since it's directly related to BlueZ, my best suggestion is that you contact them for help.
http://www.bluez.org/contact/ BlueZ " Contact
Peter.
Carlos_M_Intel
Hi Eng_akhamis
Do you still having problems with your code?
Did you check Peter's suggestion?
Charlie
akham2
