Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
send-udp.js is not recognized
Jump to solution
Hello sir,
when i am writing send-udp.js command for eg :-send-udp.js temp 21.0 i am getting error as send-udp.js command not found, i am using edison ,and using iotkit,
Community Manager
Hi Gau999,
Thanks for reaching out.
Just to clarify, send-udp.js isn't a command, it is a Javascript file.
About your issue, it looks like you are using IoT Analytics, for your information it have been discontinued (Look this thread: https://communities.intel.com/thread/107871 https://communities.intel.com/thread/107871), so if you want to use an alternative solution check: https://software.intel.com/en-us/iot/hardware/edison# cloud
Have a nice weekend.
-Leonardo
Community Manager
Hi Gau999,
-Leonardo
