Intel® Makers
9881 Discussions
sending data over internet to galileo using intel centrino
SSush1
I am a beginner trying to interface galileo with centrino.
i wanted to know how to send data over internet to galileo using centrino.
Also can I do this using ARDUINO IDE.?
Any help is apprieciated.
Community Manager
Hello sushruthn96,
I'm not sure I understand what you mean but I will try to help you with this. Could you please answer the following questions?
Are you using the Centrino card and the wireless interface of Galileo?
Or, are you trying to send data from a Galileo to a Centrino board through the internet?
How would you like to send the data?
Regarding your question about the Arduino IDE, depending on how you'd like to send the data, it should be possible to send the data from an Arduino sketch but we'd need more information about what you'd like to achieve in order to be sure.
-Peter.
SSush1
Sorry for late reply,
For example I wanted to control an LED at my house from my college.I wanted to do this using galileo and centrino.So can I do coding for this in arduino ide..
How can I send data over internet to galileo.
Help is appreciated
Community Manager
I believe what you'd like to do can be achieved by using a cloud service such as Intel's Cloud Analytics. I'd suggest you to check the following document:
https://software.intel.com/en-us/intel-iot-platforms-getting-started-cloud-analytics
-Peter.
FTinetti
Honored Contributor I
Hi sushruthn96,
Help is appreciated
Is centrino a requirement? Intel Galileo already has Ethernet hardware for Internet connection, why would you need to buy, install and use a new/expensive (related to the 0 cost/already available Ethernet) one?
Fernando.
SSush1
But to connect to my modem its better to use wifi module than drawing Ethernet cable.So if I use centrino can i code in Arduino IDE.
FTinetti
I see, fair enough.
You can code in the IDE you want/need, I think.
Fernando.
FTinetti
Replying to myself just to add some other threads about this, which seem to be solved:
HTH,
Fernando.
Community Manager
Hello sushruthn96,
Do you have any updates about this?
-Peter.
