Intel® Makers
9882 Discussions
service command not found on intel edison
Community Manager
hello everyone,
i cannot find service command on my intel edison.
when I run 'service' command it shows error like
root@edison:~# service
-sh: service: command not found
is there any similar command for this in yocto ?
Sergio_A_Intel
The service command is not available in the current Edison image. In the Edison, services are found in /lib/system/system. You can enable services, similarly how you'd do it with the service command using systemctl.
Some of the basic systemctl options to check and enable your service are:
systemctl status servicename.service
systemctl start servicename.service
systemctl enable servicename.service
You can see more options of systemctl here http://www.freedesktop.org/software/systemd/man/systemctl.html systemctl
Sergio
Sergio_A_Intel
Sergio
