Intel® Makers
9880 Discussions
sketch deleted when unplugging the power source
akham2
hi,
I'm working on Intel Edison with arduino break board and using arduinno IDE. Whenever I upload the sketch it works perfectly. My problem is when I unplug the board and plug it again, it works as I didn't upload anything (something like it deletes or doesn't save the sketch. Any suggestions?
regards,
Khamis
Diego_V_Intel
Hello Eng_akhamis,
That is a known issue that only happens with the latest image version. I recommend you to re-flash the Edison with the following image version: https://downloadcenter.intel.com/downloads/eula/24910/Intel-Edison-Software-Release-2-1?httpDown=htt... Intel Edison Software Release 2.1
In fact, this same question was posted yesterday. I recommend you to check the following thread for additional details:
Diego.
Diego_V_Intel
Hello Eng_akhamis,
Diego.
akham2
Mr. DiegoV_Intel,
Thank you very much.
