Intel® Makers
9874 Discussions
some way to program the mobile phone to be read by intel galielo + pn532
NBAR0
JesusE_Intel
Hi NBAR0, Are you trying to use the mobile phone as a NFC card and read it with Galileo? If so, you will need to write the code in Arduino and upload the sketch to the Galileo Board. Take a look at this guide: https://software.intel.com/en-us/get-started-arduino-install You will also need to install the Arduino library for the pn532. Adafruit has a library available: https://learn.adafruit.com/adafruit-pn532-rfid-nfc/arduino-library Hope this helps! Regards, Jesus
