Intel® Makers
9872 Discussions
startup script won't run while application does
HLeeu
Dear list,
Reaching out again.
My last step toward a running application and of course I run into problems again...
I have a program that runs without any problems when I run it with eclipse from my computer (MacOsX 10.9.5).
When I copy the compiled version to the Edison I can run that program also on the Edison and it works again flawlessly:
./mergeGesticUDP
Then when I try to make a startup service out of it it fails. It seems that everything goes as expected until I am already running the program. It seems that a certain action is not working.
The proces goes wrong on this portion of the code:
/* Initialize all variables and required resources of gestic */
gestic_initialize(&gestic);
/* Try to open a connection to the device */
if(gestic_open(&gestic) < 0) {
fprintf(stderr, "Could not open connection to GestIC.\n");
return -1;
When I run:
root@ediElectrumpet:/lib/systemd/system# systemctl status mergeGesticUDP.service
● mergeGesticUDP.service - GestIC data in OSC to computer
Loaded: loaded (/lib/systemd/system/mergeGesticUDP.service; enabled)
Active: activating (auto-restart) (Result: exit-code) since Fri 2017-03-31 22:22:01 UTC; 9s ago
Process: 621 ExecStart=/usr/bin/mergeGesticUDP (code=exited, status=255)
Main PID: 621 (code=exited, status=255)
Mar 31 22:22:01 ediElectrumpet systemd[1]: mergeGesticUDP.service: main process exited, code=exited, status=255/n/a
Mar 31 22:22:01 ediElectrumpet systemd[1]: Unit mergeGesticUDP.service entered failed state.
Mar 31 22:22:01 ediElectrumpet mergeGesticUDP[621]: Could not open connection to GestIC.
Mar 31 22:22:01 ediElectrumpet mergeGesticUDP[621]: GestIC-Stream-Demo version 1.2.0
It is clear that there is a problem when the program tries to make a connection to the GestIC device. This device is connected through the OTG USB connection on the Edison.
Should I include something in the .service script that says that using the USB connection is ok?
At the moment it looks like this (based on https://www.losant.com/blog/edison-automatic-process-startup https://www.losant.com/blog/edison-automatic-process-startup ):
[Unit]
Description=GestIC data in OSC to computer
Wants=network-online.target
After=network-online.target
[Service]
ExecStart=/usr/local/mergeGesticUDP/mergeGesticUDP
User=nobody
<p style="font-size: 12px; font-family: Consolas; color:...
HLeeu
Dear all,
Finally this turned out to be very easy. The problem was in the User. It turned out that it should not be 'nobody'. Found that here:
https://forums.sonarr.tv/t/sonarr-service-error-sonarr-wont-autostart/11972/5 Sonarr.service Error Sonarr Won't Autostart - Help & Support - sonarr :: forums
root@ediElectrumpet:~# whoami; id -g -n
root
root
root@ediElectrumpet:~# cd /lib/systemd/system
root@ediElectrumpet:/lib/systemd/system# vi mergeGesticUDP.service
root@ediElectrumpet:/lib/systemd/system# chmod 755 /lib/systemd/system/mergeGesticUDP.service
root@ediElectrumpet:/lib/systemd/system# chown root:root /lib/systemd/system/mergeGesticUDP.service
root@ediElectrumpet:/lib/systemd/system# systemctl daemon-reload
root@ediElectrumpet:/lib/systemd/system# systemctl start mergeGesticUDP.service
Active: active (running) since Fri 2017-03-31 22:12:27 UTC; 6s ago
Main PID: 542 (mergeGesticUDP)
CGroup: /system.slice/mergeGesticUDP.service
└─542 /usr/local/mergeGesticUDP/mergeGesticUDP
Mar 31 22:12:27 ediElectrumpet systemd[1]: Started GestIC data in OSC to computer.
Mar 31 22:12:27 ediElectrumpet libmraa[542]: libmraa version v1.0.0 initialised by user 'root' with EUID 0
Mar 31 22:12:27 ediElectrumpet libmraa[542]: gpio214: init: Failed to write to 'export': No such device
Mar 31 22:12:27 ediElectrumpet libmraa[542]: edison: Arduino board not detected, assuming Intel Edison Miniboard
Mar 31 22:12:27 ediElectrumpet libmraa[542]: libmraa initialised for platform 'Intel Edison' of type 2
In my new service file I also used the name of the service state of my USB device (I guess that if that is present it means that it is active, apparently so since the script works)
I could find the service state using this:
root@ediElectrumpet:/lib/systemd/system# systemctl status /dev/serial/by-id/usb-Microchip_Technology_Inc._GestIC_Bridge-if00
● dev-serial-by\x2did-usb\x2dMicrochip_Technology_Inc._GestIC_Bridge\x2dif00.device - CDC RS-232 Emulation Demo
Follow: unit currently follows state of sys-devices-pci0000:00-0000:00:11.0-dwc3\x2dhost.2-usb1-1\x2d1-1\x2d1:1.0-tty-ttyACM0.device
Loaded: loaded
Active: active (plugged) since Fri 2017-03-31 22:08:40 UTC; 17min ago
Device: /sys/devices/pci0000:00/0000:00:11.0/dwc3-host.2/usb1/1-1/1-1:1.0/tty/ttyACM0
So my service file now looks like this:
[Unit]
Requires=sys-devices-pci0000:00-0000:00:11.0-dwc3\x2dhost.2-usb1-1\x2d1-1\x2d1:1.0-tty-ttyACM0.device
After=sys-devices-pci0000:00-0000:00:11.0-dwc3\x2dhost.2-usb1-1\x2d1-1\x2d1:1.0-tty-ttyACM0.device
[Service]
User=root
Group=root
Restart=on-failure
RestartSec=5s
[Install]
WantedBy=sys-devices-pci0000:00-0000:00:11.0-dwc3\x2dhost.2-usb1-1\x2d1-1\x2d1:1.0-tty-ttyACM0.device
Any further advice is welcome but I am happy because it works!!!!!!
Now further making art........
Best, Hans.
HLeeu
Dear all,
root
root
Loaded: loaded
[Unit]
[Service]
User=root
Group=root
Restart=on-failure
RestartSec=5s
[Install]
Best, Hans.
