Community
cancel
Showing results for
Search instead for
Did you mean:
asing44
static ip on ubilinux
Jump to solution
I want to assign static ip to my edison which has ubilinux installed.
So far I have tried various methods but I have no success.
Please Help!!!!
Thanks in advance.
Diego_V_Intel
Hi Arjun_289,
There is a guide about configuring a static IP address in Edison, however the guide assumes you're using the Yocto image: . You could try to follow the guide using Ubilinux; nevertheless I'd recommend you to contact http://www.emutexlabs.com/ EmutexLabs for details about configuring a static IP address in Ubilinux.
Diego.
Diego_V_Intel
Hi Arjun_289,
Diego.
