Community
cancel
Showing results for
Search instead for
Did you mean:
COkon
std::invalid_argument
I keep getting this errors
terminate called after throwing an instance of 'std::invalid_argument'
what(): Invalid AIO pin specified - do you have an ADC?
Aborted
logout
I am reading an analog input and after a while of reading the data it throws in the above error. I also ran into this same type of error when I was using PWM pins. What library am I missing or is the problem from the board itself?
Pablo_M_Intel
Hi dunex_1,
Could you please tell us which version of MRAA you're using? Also, are you using the XDK or the terminal to run the code?
Are you getting this error in every program that uses an analog input or just on one specific script?
I don't think this issue has anything to do with the board, because some users have had similar messages in the past. I believe this has something to do with the library, but it would be good to have some more information.
Pablo
COkon
Hi PabloM_Intel,
The version of mraa that I am using is Version 0.7.2-r0. I am using the eclipse IDE to run the code. I am getting the error only on that particular program.
root@edison:~# opkg info libmraa0
Package: libmraa0
Version: 0.7.2-r0
Depends: libgcc1 (>= 4.9.1), python-core, libpython2.7-1.0 (>= 2.7.3), libstdc++6 (>= 4.9.1), libc6 (>= 2.20)
Provides: mraa
Status: install user not-installed
Section: libs
Architecture: core2-32
Maintainer: Poky <</span>mailto:poky@yoctoproject.org poky@yoctoproject.org>
MD5Sum: e34c2bbf2f5484b512f4da516c2d1bbb
Filename: libmraa0_0.7.2-r0_core2-32.ipk
Source: git://github.com/intel-iot-devkit/mraa.git;protocol=git;rev=299bf5ab27191e60ea0280627da2161525fc8990
Description: Low Level Skeleton Library for Communication on Intel platforms Low
Level Skeleton Library for Communication on Intel platforms.
Pablo_M_Intel
Hi dunex_1,
The first thing that I would suggest you is to update your version of mraa. Version 0.9.x is already available, https://github.com/intel-iot-devkit/mraa https://github.com/intel-iot-devkit/mraa. You could also try to change the analog pins that you're using to discard any software issue. Could you please tell me which pin you're using and how you're configuring it?
It would also be a good idea to see the program that you're using.
Pablo
COkon
Hi PabloM_Intel
I am using all the analog pins on the board to get an analog reading from 5 sensors. And this is how I am configuring them
global variables
mraa::Aio* a0 = new mraa::Aio(0);
mraa::Aio* a1 = new mraa::Aio(1);
//mraa::Aio* a2 = new mraa::Aio(2);
//mraa::Aio* a3 = new mraa::Aio(3);
//mraa::Aio* a4 = new mraa::Aio(4);
void read_sensor(){
adc_value0 = a0->read();
adc_value1 = a1->read();
//adc_value2 = a2->read();
//adc_value3 = a3->read();
//adc_value4 = a4->read();
cout << " " << endl;
cout << "Sensor 1: " << adc_value0 << " cm" << endl;
cout << "Sensor 2: " << adc_value1 << " cm" << endl;
//cout << "Sensor 3: " << (adc_value2*5)/10 << " cm" << endl;
//cout << "Sensor 4: " << (adc_value3*5)/10 << " cm" << endl;
//cout << "Sensor 5: " << (adc_value4*5)/10 << " cm" << endl;
And then I call the read_sensor() function every one-tenth of a second from main
Pablo_M_Intel
Hi dunex_1,
Have you tried isolating each section of the code (each analog input) to determine which one is causing the issue? I see that you have some code commented out, that's why I'm asking. Also, were you able to update the mraa library?
Pablo
