Intel® Makers
storage
aselv1
Hi
actually i am running yocto image in my intel edison
and in dev/root is fully used but i have some memory in
devtmpfs 480M 0 480M 0% /dev
tmpfs 481M 0 481M 0% /dev/shm
tmpfs 481M 548K 480M 1% /run
tmpfs 481M 0 481M 0% /sys/fs/cgroup
tmpfs
how can i transfer this unused memory to dev/root to provide some space to root
i have already working on the edison module with out flashing or formatting is there possible to get the memory to be updated.
Thanks in advance
Community Manager
Hello Ayyappan91,
Thank you for your interest in the Intel® Edison Breakout Board.
The two methods that enable you to change the size of the root partition require flashing/formatting the board. If you want to check them, please follow this links:
Increasing the Root Partition Size on Intel® Edison Boards
https://www.intel.com/content/www/us/en/support/boards-and-kits/000005955.html
Booting Your Edison from an SD (Linux)
https://communities.intel.com/docs/DOC-111602 https://communities.intel.com/docs/DOC-111602
So, unfortunately, a method to perform a resize of the partitions without flashing/formatting the board is not available.
If you have any update or question, don't hesitate to contact us.
Have a nice day.
Andres V.
