Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
sudo doesnt work for me on edison linx console.
Jump to solution
I am fairly new to linux and when i try to use sudo to install new packages/modules on my new edison, i get error sudo as undefined. Is there an alternative for Sudo or way to install it. Any advice?
Abhi
Accepted Solutions
Highlighted
Re: sudo doesnt work for me on edison linx console.
Jump to solution
You are root on Edison right away, no need in sudo. If you have already created an unprivileged user and want to access root from it, you can install sudo from the package repo:/message/254806# 254806 https://communities.intel.com/message/254806# 254806
Highlighted
Jump to solution
