Community
cancel
Showing results for
Search instead for
Did you mean:
DRoss4
symbol lookup error: ... undefined symbol: ...
Jump to solution
Hi all, I am trying to run this simple C++ code in Eclipse to test a HC-SR04 sensor on my Edison + Arduino Breakout:
# include "mraa.hpp"
# include "hcsr04.h"
# include
# include
# include
# include
# include
# include
upm::HCSR04 *sonar = NULL;
void
sig_handler(int signo)
printf("got signal\n");
if (signo == SIGINT) {
printf("exiting application\n");
sonar->m_doWork = 1;
void
interrupt (void * args) {
sonar->ackEdgeDetected ();
int main()
setvbuf(stdout, NULL, _IONBF, 0);
sonar = new upm::HCSR04(2, 3, &interrupt);
signal(SIGINT, sig_handler);
printf ("width = %d\n", sonar->getDistance());
delete sonar;
return 0;
The code compiles without problems, but when running on the board I get this error in the console:
/tmp/SensorTest: symbol lookup error: /tmp/SensorTest: undefined symbol: _ZN3upm6HCSR0411getDistanceEv
Could someone point what is the problem? Thanks.
DRoss4
Looks like I solved it by myself. It appears that I had different versions of the required libraries on the board and on Eclipse. Downloaded the matching version to the Eclipse repository and rebuilt the indexes, now everything seems to work fine.
DRoss4
