Intel® Makers
9868 Discussions
target firmware version failed
MDibi
Hi, I get the message " target firmware version failed" everytime i try to update the firmware. I'm on a mac book pro osx 10.8.5 ... please help me
ASalv2
Hi! Make sure that you have selected the right serial port in the Arduino IDE (from the Tools menu). If the error still persists, try to move the IDE installation directory to a path that does not contain spaces -- it causes errors for the Windows version of the program, so I think it can do the same also on MacOS.
Hope this helps!
ASalv2
Hope this helps!
MDibi
Thank you! the problem was that I renamed the file (Arduino Galileo) just to be sure of compatibility issues with the libraries I use with the "old" arduino IDE.. Changing the name solved the problem.
