I am using Intel Edison Mini breakout board and I trying to connect an SD card. I use https://www.aliexpress.com/store/product/5V-3-3V-Compatible-Perfect-SD-Card-Module-Slot-Socket-Reade... Aliexpress.com : Buy 5V/3.3V Compatible Perfect SD Card Module Slot Socket Reader For ARM MCU Read And Write CNT 002 fr… and I connect:
Pin 1 - NC
Pin 2 - GND
Pin 3 - V_V3P30
Pin 4 - NC
Pin 5 - GP83 (SD_DAT3)
Pin 6 - GP79 (SD_CMD)
Pin 7 - GP78 (SD_CLK)
Pin 8 - GP80 (SD_DAT0)
Pin 9 - NC
When I trying commend: dmesg |tail -n 10 I get:
[ 15.394883] wl_bss_connect_done succeeded with a0:63:91:03:28:fc
[ 15.461597] wl_bss_connect_done succeeded with a0:63:91:03:28:fc
[ 16.512393] ip (373) used greatest stack depth: 4932 bytes left
[ 18.754499] snd_intel_sst: Stop for str 14 pipe 0xe
[ 18.754984] snd_intel_sst: Free for str 14 pipe 0xe
[ 18.759099] snd_intel_sst: Stop for str 1 pipe 0x90
[ 18.759672] snd_intel_sst: Free for str 1 pipe 0x90
[ 18.762102] snd_intel_sst: runtime_idle called
[ 20.752563] snd_intel_sst: runtime_suspend called
I don't know what I did wrong.
Hello Maciej,
Thank you for your interest in our Intel products.
In order to use an SD card interface with the mini-breakout board I think you could take a look at the http://www.intel.com/support/edison/sb/CS-035272.htm Schematic of the Arduino Expansion Board (SD Card - Section)
If you want to wire something to the mini breakout board you must always check the hardware guide of thehttp://www.intel.com/support/edison/sb/CS-035274.htm Edison Compute Module and the http://www.intel.com/support/edison/sb/CS-035252.htm Mini-Breakout board.
More documents in: https://www-ssl.intel.com/content/www/us/en/support/edison-documents-and-guides.html Intel® Edison Documents and Guides
You can use an SD or USB drive for storage, you can also create your own image with different partitions. [http://www.intel.com/support/edison/sb/CS-035278.htm Intel® Edison Boards — Board Support Package (BSP) User Guide]
About the A2DP connections; you can check the http://www.intel.com/support/edison/sb/CS-035381.htm Intel® Edison Boards — Bluetooth* User Guide
Miracast, airplay.... Do you want to attach a webcam to the board and then stream video to another device? For example you can use gstreamer too.
Hope this helps.
Octavian
