Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
New Contributor III
u-boot compile troubles
what could be the case to have the following error message?
| DEBUG: Executing shell function do_compile
| NOTE: make -j 2 CROSS_COMPILE=i586-poky-linux- CC=i586-poky-linux-gcc --sysroot=/home/build/yocto/build/tmp/sysroots/edison edison_config
| make: *** No rule to make target `edison_config'. Stop.
| make: *** [edison_config] Error 1
| ERROR: oe_runmake failed
Highlighted
Re: u-boot compile troubles
Hello Andre.M,
Could you be a little bit more specific about your issue, what steps did you take before this error showed?
Peter.
Highlighted
New Contributor III
its no longer important
