Intel® Makers
9872 Discussions
ubilinux battery-voltage utility
ARoca1
Hello!
I have an intel edison with Ubilinux and a battery which I use as a portable server. Does somebody know if it's possible to install the yocto battery-voltage (http://git.yoctoproject.org/cgit/cgit.cgi/meta-intel-edison/tree/meta-intel-edison-distro/recipes-su... src here) utility to check the battery levels? This c program uses the /sys/devices/platform/pmic_ccsm/battery_level file which is not present in the ubilinux built. Any idea? Some kernel module to activate?
Thank you!
Pedro_M_Intel
Hello aleixrocks,
As you mentioned, the code was written for Yocto, and may not be compatible with Ubilinux. I believe you will get a more accurate answer in http://www.emutexlabs.com/forum/ubilinux EmutexLabs.
Peter.
Pedro_M_Intel
Hello aleixrocks,
Peter.
ARoca1
Ok! I will also ask it there. I wanted to ask it here first because it seems that there is not much activity in the EmutexLabs lately...
Thank you Intel_Peter!
