Intel® Makers
9880 Discussions
ubuntu stick lack of memory errors
BBruc51
I've got my intel ubuntu stick connected to my old motorola atrix lapdock. It works very well but because of lack of memory errors I can not do any updating of ubuntu. What is the best solution to this problem? I've removed several applications but that does not free up enough to update.Any help is appreciated.
linuxium
New Contributor III
I'd probably use a separate partition for /home making the new mount point on the micro SD card and so freeing up additional storage for the Ubuntu OS. There are plenty of guides on the web explaining how to do this. Another benefit is it will allow you to re-install Ubuntu without loosing your data.
Community Manager
Hello:
Thank you very much to linuxium for the information posted above, it will be very helpful for all the peers viewing this thead.
To brucebills:
Another option will be to try to transfer all the storage data or information to the SD card, by doing that you will be able to free memory space on the stick to do the Ubunto update.
Alberto
