Intel® Makers
9868 Discussions
unable to blink onboard led on intel galileo gen 2 board
skhar3
i tried to blink onboard led but didnt succeed.....
used gpio3=>for onboard led
>>echo -n "3" /sys/class/gpio/export
>>echo -n "out" /sys/class/gpio/gpio3/direction
>>echo -n "1" /sys/class/gpio/gpio3/value
>>echo -n "strong" /sys/class/gpio/gpio3/drive
is it sufficient or i missed something ?
FTinetti
Honored Contributor I
Hi shaileshkharche,
Take a look at threads like
(take into acount that gpio numbering of Intel Galileo Gen2 is not the same as that of Intel Galileo)
HTH,
Fernando.
Community Manager
Hi shaileshkharche,
Do you still need assistance with this case? We'll be waiting for your response.
-Sergio A
pmanj
Hi Shailesh,
I am doing the same assignment and facing the same issue. I also tried with gpio7 pin. But it is not working.
If you can kindly suggest anything please let me know.Also, if you need 3.3 v voltage for I/O pins then how will you connect IOREF pin to 3.3 v pin?Had you done any such connection?
Poornima
