Intel® Makers
9881 Discussions
unable to set setenv on u-boot configuration for Linux kernel on Intel Edison
sk23
New Contributor II
Hi ,I followed the below steps base on this links.https://edison.internet-share.com/wiki/Using_a_vanilla_Linux_kernel_with_Intel_Edison https://edison.internet-share.com/wiki/Using_a_vanilla_Linux_kernel_with_Intel_Edison https://habrahabr.ru/post/254247/ Запускаем свежайшее ядро Linux на Intel Edison / Хабрахабр
*** Ready to receive application ***
U-Boot 2014.04 (Jun 06 2016 - 14:40:07)
Watchdog enabled
DRAM: 980.6 MiB
MMC: tangier_sdhci: 0
In: serial
Out: serial
Err: serial
Hit any key to stop autoboot: 0
boot >
boot >
boot > setenv boot_edsboot 'zboot 0x100000 0 0x800000 0x800000'
boot > setenv bootargs_edsboot 'console=tty1 console=ttyS2,115200n8 root=/dev/ram0 rw initrd=0x800000,8M'
boot > setenv bootcmd_edsboot 'setenv bootargs ${bootargs_edsboot}; run load_edsboot; run boot_edsboot'
boot > setenv load_edsboot 'load mmc 0:9 0x100000 vmlinuz.efi; load mmc 0:9 0x800000 initrd'
boot > saveenv
Saving Environment to MMC...
Writing to redundant MMC(0)... done
boot > run bootcmd_edsboot
ERROR
run bootcmd_edsboot
reading vmlinuz.efi
** Unable to read file vmlinuz.efi **
reading initrd
** Unable to read file initrd **
Error: Invalid Boot Flag (found 0xffef, expected 0xaa55)
# Kernel loading failed ...
zboot - Boot bzImage
Usage:
zboot [addr] [size] [initrd addr] [initrd size]
addr - The optional starting address of the bzimage.
If not set it defaults to the environment
variable "fileaddr".
size - The optional size of the bzimage. Defaults to
zero.
initrd addr - The address of the initrd image to use, if any.
initrd size - The size of the initrd image to use, if any.
I was unable to find the issue.could you please help me.
asss
Valued Contributor II
it seems vmlinuz.efi and initrd are not available for U-boot to read.
1. May you provide an output of
boot > mmc part
boot > fatls mmc 0:9
boot > fatinfo mmc 0:9
boot > mmcinfo
2. Where have you placed vmlinuz.efi and initrd ?
BR,
xbolshe
Community Manager
Have you followed the previous steps of the guide and build the kernel before attempting to change the environmental variables?
-Sergio
sk23
New Contributor II
Hi Sergio ,
Thank you for support.
I build the kernel and build root and copied both files into emm 0:9 using below links.
$cp linux-next/arch/x86/boot/bzImage //vmlinuz.efi
$ cp buildroot/output/images/rootfs.cpio.bz2 //initrd
lsblk on Host
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 931.5G 0 disk
├─sda1 8:1 0 100M 0 part
├─sda2 8:2 0 217.5G 0 part
├─sda3 8:3 0 247.9G 0 part
├─sda4 8:4 0 1K 0 part
├─sda5 8:5 0 458.1G 0 part /
└─sda6 8:6 0 7.9G 0 part [SWAP]
sdb 8:16 0 768M 0 disk /media/srinivas/5776-0E2F
sr0 11:0 1 1024M 0 rom
mmc part
1 0x00000800 0x000017ff "u-boot0"
attrs: 0x0000000000000000
type: ebd0a0a2-b9e5-4433-87c0-68b6b72699c7
guid: d117f98e-6f2c-d04b-a5b2-331a19f91cb2
2 0x00001800 0x00001fff "u-boot-env0"
guid: 25718777-d0ad-7443-9e60-02cb591c9737
3 0x00002000 0x00002fff "u-boot1"
guid: 8a4bb8b4-e304-ae48-8536-aff5c9c495b1
4 0x00003000 0x000037ff "u-boot-env1"
guid: 08992135-13c6-084b-9322-3391ff571e19
5 0x00003800 0x00003fff "factory"
guid: 333a128e-d3e3-b94d-92f4-d3ebd9b3224f
6 0x00004000 0x0000ffff "panic"
guid: f20aa902-1c5d-294a-9177-97a513e3cae4
7 0x00010000 0x0001ffff "boot"
guid: db88503d-34a5-3e41-836d-c757cb682814
8 0x00020000 0x0031ffff "rootfs"
guid: 012b3303-34ac-284d-99b4-34e03a2335f4
9 0x00320000 0x0049ffff "update"
guid: faec2ecf-8544-e241-b19d-757e796da607
10 0x004a0000 0x00747fde "home"
guid: f13a0978-b1b5-1a4e-8821-39438e24b627
fatls mmc 0:9
6516048 vmlinuz.efi
1692950 initrd
2 file(s), 0 dir(s)
Interface: MMC
Device 0: Vendor: Man 000090 Snr 018d33a8 Rev: 0.3 Prod: H4G1d
Type: Removable Hard Disk
Capacity: 3728.0 MB = 3.6 GB (7634944 x 512)
Filesystem: FAT32
boot > mmcinfo
Device: tangier_sdhci
Manufacturer ID: 90
OEM: 14a
Tran Speed: 52000000
Rd Block Len: 512
MMC version 4.5
High Capacity: Yes
Capacity: 3.6 GiB
Bus Width: 8-bit
Still i was unable to load new kernel and build root into device.
Here is the crashfile logs on device
EVENT=HWWDG
Manufacturer : Intel Corporation
Product name :
Version :
Serial Number : FZED445D0206G501
Linux version : Linux edison 3.10.98-poky-edison+ # 2 SMP PREEMPT Mon Jul 4 12:36:35 IST 2016 i686 GNU/Linux
Build version : 201607041232
Date : Fri Jul 1 06:08:33 UTC 2016
Wake source : HWWDT reset SC
Could you please suggest/provide the details. what is wrong in my process ?
sk23
New Contributor II
Hi Sergio ,
Any idea about below issue ?
While run bootcmd_edsboot on u-boot prompt kernel version is 4.7.0 but unable load the this kernel.
On target
uname -r
root@edison:~# uname -a
Linux edison 3.10.98-poky-edison+ # 1 SMP PREEMPT Wed Jul 6 18:03:37 IST 2016 i686 GNU/Linux
I was unable to load the latest kernel. Please do need full.
Community Manager
It seems from that last picture that the new kernel was build but is not loading. After the "Starting kernel…" message is there any more output from the console? After seeing this message the kernel should start booting and at the end of the process you should see a Welcome to Buildroot. Are you not seeing this?
There's also a note in the guide that says that after you configure the variables, it will be possible to boot the new system if the normal boot is interrupted by pressing a key during boot (at the right time). You can see this note in the U-boot section of the guide.
-Sergio
sk23
New Contributor II
Hi Sergio ,
I was doing same steps but unable load new kernel image.
I have given the steps and logs on my previous thread.
I short i am running this command after setting the image and env variables.
Please do need full
Community Manager
From the screenshot of your console, just after you typed run bootcmd_edsboot there's a line that says "Linux kernel version 4.7.0-rc6-next-20160708" and the guide you're following has "Linux kernel version 4.1.0-rc6+". Which file have you cloned in the first step of the guide?
What happens after that screenshot? Does the log continue or does it just freezes there?
-Sergio
sk23
New Contributor II
Screen shoot for you reference. I was unable boot new kernel.
is there any other command need to perform ?
Community Manager
What I meant was if you cloned the same kernel as in the guide https://edison.internet-share.com/wiki/Using_a_vanilla_Linux_kernel_with_Intel_Edison https://edison.internet-share.com/wiki/Using_a_vanilla_Linux_kernel_with_Intel_Edison or if you used another kernel. I ask this because the kernel on the guide differs from the one in your console log.
-Sergio
Andriy_S_Intel
I can add to the above answers that I run linux-next on Intel Edison board more often than once per week. I don't do that for stable kernel so frequently.
sk23
New Contributor II
Hi Sergio ,
I was using same kernel.still i was getting same issue.
Srinivas
Andriy_S_Intel
Just tried kernel from
https://github.com/andy-shev/linux/tree/eds https://github.com/andy-shev/linux/tree/eds
buildroot login: root
# uname -a
Linux buildroot 4.7.0-rc7+ # 21 SMP Mon Jul 18 16:22:37 MSK 2016 x86_64 GNU/Linux
# lspci -nk | tail -n10
Kernel driver in use: intel_scu_ipc
00:14.0 0b40: 8086:11a1 (rev 01)
Kernel driver in use: intel_mid_pwr
00:15.0 0880: 8086:11a2 (rev 01)
Kernel driver in use: dw_dmac_pci
00:16.0 0b40: 8086:11a3 (rev 01)
00:16.1 0b40: 8086:11a4 (rev 01)
00:17.0 0880: 8086:11a5 (rev 01)
Kernel driver in use: pwm-lpss
00:18.0 0380: 8086:11a6 (rev 01)
Andriy_S_Intel
One more thing, be sure that you have enough memory between vmlinuz.efi and initrd to be able to decompress them. It might be that one of your images (initrd or vmlinuz.efi) overlaps the other when being decompressed.
Community Manager
Do you still need help with this thread?
-Sergio
Andriy_S_Intel
Okay, I tried to follow my instructions for v4.7, and found you are right. They do not apply anymore for newest kernels. What you need to change is:
boot > setenv boot_edsboot 'zboot 0x100000 0 0xc00000'
(Note you have to replace 0x800000 by 0xc00000 in the rest of custom U-Boot variables as well)
The second issue is that kernel unable to mount initrd. I'm looking into it right now.
RAtlu1
New Contributor II
Andy
I am gonna try out a custom u-boot build 2015 v and your latest kernel with a custom initramfs and report back. On the side note, initramfs never ever worked on edison board (could be u-boot issue)
Andriy_S_Intel
I found a root cause. To resolve the issue just use an updated example of U-Boot variables:
setenv boot_edsboot 'zboot 0x100000 0 0x3000000 0x800000'
setenv bootargs_edsboot 'console=tty1 console=ttyS2,115200n8 rootfstype=ramfs rw'
setenv load_edsboot 'load mmc 0:9 0x100000 vmlinuz.efi; load mmc 0:9 0x3000000 initrd'
# uname -a
Linux buildroot 4.8.0-rc2-next-20160818+ # 1 SMP Thu Aug 18 19:47:15 EEST 2016 i686 GNU/Linux
And do not forget to use proper initrd file size in zboot 4th parameter.
