I've been trying to connect a nrf24l01 module to a edison breakout board but unfortunately when I try to run a node based example I always get a Segmentation fault error.
Below is the code I use:
var m = require('mraa');
var nrf = require('jsupm_nrf24l01');
// setup the rf unit with configurable pin options:
var comm = new nrf.NRF24L01(9,23);
// debug:
//console.log(nrf);
//console.log(comm);
var running = 0,
localAddress = [], // ??? [0x01, 0x01, 0x01, 0x01, 0x01]
broadCastaddress = [], // ?? [0x01, 0x01, 0x01, 0x01, 0x01] ,
sigHandler = function(sig){
var msg = "got signal: ";
console.log(msg,sig);
running = 1;
nrf_handler = function(){
var msg = "recieved:: ";
console.log(msg,nrf.m_rxBuffer[0]);
/* reference: upm/nrf24l01-receiver.cxx at master · intel-iot-devkit/upm · GitHub
comm = new upm::NRF24L01(7, 8);
comm->setSourceAddress ((uint8_t *) local_address);
comm->setDestinationAddress ((uint8_t *) broadcast_address);
comm->setPayload (MAX_BUFFER);
comm->configure ();
comm->setSpeedRate (upm::NRF_250KBPS);
comm->setChannel (99);
comm->dataRecievedHandler = nrf_handler;
comm.setSourceAddress(localAddress);
comm.setDestinationAddress(broadCastaddress);
comm.setPayload(16);
comm.configure();
comm.setSpeedRate(nrf.NRF_250KBPS);
comm.setChannel(99);
comm.dataRecievedHandler = sigHandler;
console.log(comm);
Can anyone help me with this issue? Thanks in advance
Hi Rubik
I found this thread: with your same issue, in that case intel_dan suggested to use the following code:
var comm = new nrf.NRF24L01(7,8);
// debug:
//console.log(nrf);
var running = 0,
running = 1;
comm->configure ();
comm.setSourceAddress(new ArrayBuffer(localAddress));
comm.configure();
console.log(comm);
I tested and did not have the error as before (I was having the same error that you.) But I'm not sure if it's working fine because I don't have a shield to test it.
I was looking in the examples of UPM for Javascript and did not find this example. I found another one but is in C++ you can try with this one too. https://github.com/intel-iot-devkit/upm/tree/master/examples/c%2B%2B upm/examples/c++ at master · intel-iot-devkit/upm · GitHub
Regards;
CMata
I tried exactly that code and a simplified version as follows:
// -- start code
// Simple test program for the NRF24L01 on the Galileo 2
var m=require('mraa');
var nrf=require('jsupm_nrf24l01');
console.log('MRAA version: ' + m.getVersion());
var comm = new nrf.NRF24L01(8,9);
SourceAddress = [1,2,3,4,5];
comm.setSourceAddress(new ArrayBuffer(SourceAddress));
console.log('Done setting address');
// --- end code
This produces an output as follows
MRAA version: v0.6.2
[11568.327992] node[241]: segfault at 0 ip b76770ee sp bfe9abc0 error ffff0004 in jsupm_nrf24l01.node[b7670000+1d000]
The hardware is a Galileo Gen 2 board with a fresh install of the IOT dev kit.
Hi CMata,
Thanks for the quick reply.
I've tried to work with the C++ example but I have 2 issues:
1. I do not know hot to compile it as I'm working directly on Intel Edison, through SSH and I do not know all the parameters required by g++ to compile and link mraa and upm libraries
2. I'm using the Mini Breakout board and onthis one the CE and CSN pins are not 7 and 8 ... I'm not sure which ones are but I assumed they are MRAA-9 and MRAA-23, as I deducted from the ediosn pinout table
Rubik
Hi Rubik,
In order to compile the UPM examples for C++ you have to do something like the following:
Let's say you are going to use the https://github.com/intel-iot-devkit/upm/blob/master/examples/c%2B%2B/nrf24l01-broadcast.cxx Broadcast.cxx example. Once you have the code in your board you need to run:
root@edison:~# g++ broadcast.cxx -o output -lupm-nrf24l01 -I /usr/include/upm
And for running the executable:
root@edison:~# ./output
About your second question, do you want to know which is the physical pin in the Edison Module that is connected to the pins 7 and 8 of the Arduino Expansion Board? If this is the case the pins for 7 and 8 are:
32 and 34, GP48 and GP49 , J19 - pin 6 and J20 - pin 6.
Arduino Expansion Board pin
Pin NumberLinux PinMini Breakout Board pin732GP48 J19 - pin 6834GP49 J20 - pin 6http://download.intel.com/support/edison/sb/edisonmodule_hg_331189004.pdf Edison Compute Module - Hardware Guide
http://download.intel.com/support/edison/sb/edisonbreakout_hg_331190006.pdf Breakout Board - Hardware Guide
http://download.intel.com/support/edison/sb/edisonarduino_hg_331191007.pdf Arduino Expansion Board - Hardware Guide
Kind Regards,
Charlie
I was trying to compile this and was getting reference error on all nrf24l01 functions.
When I applied your solution I got:
/tmp/ccdqB9Zu.o: In function `main':
broadcast.cxx:(.text+0x3ae): undefined reference to `upm::NRF24L01::~NRF24L01()'
collect2: error: ld returned 1 exit status
Hi sulejmansarajlija,
It could be related with your image, mraa or upm version.
For this I suggest you to use the latest image in your board and to update the mraa and upm version you have installed on the board.
Charlie
Hi CMata_Intel , I think it was version mismatch. Can somebody here help me with pins on Arduino Edison breakout board. Can't figure out for MISO, MOSI, SCK, CE, CS.
The pins for SPI on the Arduino Expansion Board are:
PinDefinitionIO10CSIO11 MISOIO12 MOSIIO13 SCKTake a look at the hardware guides of:
http://download.intel.com/support/edison/sb/edisonmodule_hg_331189004.pdf Compute Module
Charlie
