Intel® Makers
9881 Discussions
update to Node 0.12.7 and xdk-daemon not working...
mkawa8
Hello
I tried upgrade to Node 0.12.7 by below command
root@edison~:opkg upgrade nodejs
and restart Edison. However xdk-daemon 0.0.35 not working
may be the daemon repeat restart process. and Not found Edison from XDK
Did not work xdk-daemon with Node 0.12.7 ?
mkawa8
Now I installed xdk-daemon 0.0.37 from http://git.yoctoproject.org/cgit/cgit.cgi/meta-intel-iot-middleware/commit/recipes-devtools/xdk-daem... meta-intel-iot-middleware - Shared middleware recipes for Intel IoT platforms
When this version upload to opkg repository...?
mkawa8
In addition my software stack is...
Yacto OS Release2.1(weekly159)
node: v0.12.07
mraa: v0.8.0
xdk: v2170
mkawa8
Carlos_M_Intel
Hi masato-ka,
If you are talking about this repository: http://repo.opkg.net/edison/repo/ Index of /edison/repo it is managed by AlexT.
If this is the case maybe AlexT_Intel could help us with this.
Charlie
mkawa8
Hi CMata_Intel
Thank you.
OK, I send request to AlexT_Intel.
However, This release is intel official release?…Or Test?, 3rd Party?
If you know that, please tell me.
masato-ka
Carlos_M_Intel
Hi masato-ka,
About the repository: http://alextgalileo.altervista.org/edison-package-repo-configuration-instructions.html Edison Package Repo Configuration Instructions
As you can in there:
This is not any kind of an official or Intel-endorsed repo. Packages are compiled with the latest official BSP as the base and I'm doing some basic tests, but as with everything in the Makers world you use that on your own risk :-) ...
This repo works really well and it is being updated very often
Charlie
AT9
Well, if node.js works and xdk-daemon is not, then maybe it's simply not compatible with this newer version of the node.js?
mhahn, any idea who could know more about xdk-daemon and Node.js version compatibility?
AT9
Ok, never mind, masato-ka told me in a private message that updating to xdk-daemon 0.0.37 fixed this for him, so I'll add this newer version to my repo, added this to my packaging ToDo list.
mkawa8
AlexT_Intel
Thank you for message.
I'm waiting update your repository :-)
Dan_Y_Intel
The daemon that is bundled with the IoTDevKit contains a node module (mdns) that is pre-compiles against node 0.10.x headers. In order for the daemon to work on a machine running node 0.12.x the module needs to be compiled against the node 0.12.x headers.
One way to do this is by upgrading the the mdns node module.
cd /opt/xdk-daemon/current/node_modules/
npm update mdns@2.2.10
systemctl restart xdk-daemon
Note: The mdns node module is needed for automatic device detection to function properly
Edit # 1: As masato-ka mentioned extractiing the contents of http://download.xdk.intel.com/iot/xdk-daemon-0.0.37.tar.bz2 http://download.xdk.intel.com/iot/xdk-daemon-0.0.37.tar.bz2 and running setup.sh will also install the daemon (and compile the nessicary node modules in the process)
mkawa8
@intel_dan
Thank you dan.
Ok, I will try update mdns with xdk-daemon 0.0.35.
mkawa8
@intel_dan
I tried your recommend commands.
After, xdk-daemon started.
However, npm update mdns@2.2.10 therefor , I run below command.
root@edison~:npm install mdns
started rebuild mans after the command.
Regards.
