I am trying to build kernel image for edison, for linux kernel -4.x
We followed https://github.com/htot/meta-intel-edison/tree/morty https://github.com/htot/meta-intel-edison/tree/morty and I faced some issues with mraa library, so I changed BB file(SRC_URI) and building was successful.
But u-boot-env files, u-boot-edison.img, edison-image-edison.hddimg were not created after build.
When I'm trying to flash onto edison it was looking for above files
- we built on linux host which is Ubuntu 14.04LTS of x86-64 architecture
- we tried with both make and bitake
Thanks and Regards,
kavitha
You've posted this query to the Intel NUC forum. You need to move it to the Edison forums to get a knowledgeable response (I couldn't do this for you)...
I guess the best person to answer is FerryT
Hello build,
Thank you for your interest in the Intel® Edison Breakout Board.
You mention that you are using this experimental morty branch: https://github.com/htot/meta-intel-edison/tree/morty. If you look at the How to use this section, at the bottom part, you'll notice this link https://github.com/htot/meta-intel-edison/wiki, which directs you to the following warning message:
The Morty branch is highly experimental. Currently it build, installs and boots, albeit the separate parts (u-boot, kernel and rootfs) which need to be installed manually.
So, according to this message, you are experiencing an expected behavior (u-boot and its files are not created) and you should add the desired files manually.
If you have any other question, don't hesitate to contact us.
Have a nice day.
Andres V.
Did you follow the instructions on the wiki page?
Currently the u-boot image is not to be trusted, I recommend building that separately. The rootfs goes to a sdcard and the kernel with initramfs goed to an empty partition on the edison. home partition stays the same. I think you were trying the flashall script, and yes, that won't work now.
I am surprised that mraa doesn't build, I thought I fixed that. I might be that a certain dependency is missing, can you post the error message?
It might be I didn't see this becauset when you use:
bitbake -k edison-image
the second time it will complete the build without error (-k tries to continue building as much as possible after an error and I believe this resolves the missing dependency)
And yes, you need to manually change env files.
If you find any info missing on the wiki I will gladly try to improve.
Hello build,
I was wondering if you could check the question and the recommendation provided by FerryT.
If you have any update or question, don't hesitate to contact us.
Andres V.
