Community
cancel
Showing results for
Search instead for
Did you mean:
JD11
using an FTDI device
We have a couple of edison devices.
so I've got my ftdi device plugged into the (arduino) breakout board and the switch is closest to the USB host port. I've got a fresh instance of the latest (3.10.17?) yocto image on there, and have added the `repo.opkg.net/edison` repos to `/etc/opkg/base-feeds.conf` and updated/etc but even tho `kernel-module-ftdi-sio` is installed it doesn't pick up the device. `lsusb` reports `unable to initialize libusb: -99` and I've tried a bunch of other things to get it to work but I'm stuck now.
I also tried adding `iotdk.intel.com/repos` things to `/etc/opkg/itodk.conf` as reported at various places, but a) the 1.1 repos in all the blog posts I've seen don't have any newer versions, and are out of date and b) trying the 1.5 versions of the urls insists on updating EVERY package on the device because they all have a spurious .0 appended to the package name/version ????
We had no problems using the ubilinux that was on one of our edisons, but the newer one constantly reports that the (latest?) image is too large for the disk (by like 2x) so we tried Yocto and that worked other than this usb junk.
Carlos_M_Intel
Hi R2DJoe,
With the Arduino Expansion Board and using the command lsusb you should be having the following results:
The switch closest to the micro USB ports
The switch closest to the USB Host
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
What is the output of running the command configure_edison --version and uname -a?
Which are the specifications of the power supply you are using? If you are getting the message "unable to initialize libusb: -99" in both positions of the switch the problem could be that the power is not enough for using the USB Host. This also happens with the Breakout Board if a power supply is not used.
Please let us know the current and voltage specifications of the power supply you are using before trying with another one. Remember that the valid range is 7V – 15V
This is a thread related to what you want to accomplish, take a look at it, it may be helpful:
Charlie
JD11
root@edison:~# configure_edison --version
159
root@edison:~# uname -a
Linux edison 3.10.17-poky-edison+ # 1 SMP PREEMPT Fri Jun 19 12:06:40 CEST 2015 i686 GNU/Linux
moving the switch doesn't fix the -99 error, and I'm using the power supply that came with it.
Carlos_M_Intel
Hi R2DJoe,
The Edison Module + Arduino Expansion Board do not include a power supply.
Did you bought a development kit? Could you provide a link to the kit you are using?
Could you test the output of the power supply? This is to verify the real voltage and current in it.
Is this the only problem you are having with the board?
What is the output of running dmesg | grep usb with the switch closest to the USB OTG?
Charlie
JD11
the power supply is 12V 4A
the -99 appeared whcihever way the switch was left
we ended up figuring out how to flash ubilinux so this topic is defunct
MPapi
Does this help?
Don't nave an Arduino myself but on my custom board i got it when i inverter RX/TX to the ftdi ... oops.
