Community
cancel
Showing results for
Search instead for
Did you mean:
ASRIV6
using galileo serial port
Hi, may be i am going a silly question, but it may be a very-very meaningful question,
in galileo there seems five serial ports,
1. Serial port near LAN port (labelled GRN)---- used to access Linux terminal/console
2. client usb ------ used serial.begin, serial.println etc in arduino sketch
3. arduino header pins 0 and 1 (Rx, Tx) ------ digital pins
4. USB host
5. use any pins as serial (Rx, Tx) by using SoftwareSerial library just like we do in arduino board
so which ports, pins can be used as serial?, how to use them in arduino sketch, python, java, c++, XDA,
Win-IoT etc
I found a tutorial in which it was written we can use GRN port as serial by using Serial2 in arduino sketch (i.e., use Serial2.begin(), etc) and an another tutorial which says we can use USB host to read/write data in a pendrive by arduino sketch etc
I have not tried these yet
Pls help me exploring hardware and software serial ports in galileo
Pls reply soon
thanks in advance
thanks
FTinetti
Honored Contributor I
Hi megalileo,
I wonder why you need to know all of those alternatives...
I've used mostly Arduino programming in Galileo and, as you already pointed out for each of them, you already know how to use almost all of them in/from Arduino sketches, so the list in
Win-IoT etc
should be "reduced" to "python, java, c++, XDA, Win-IoT etc"
I would like to know the references you have seen for
I've not seen any tutorial/way of using the USB host, did you?
Fernando.
Community Manager
Hi megalileo,
There are no silly questions, please ask all you want, we will be glad to help you.
If you want to use the Arduino IDE, you can use the SoftwareSerial library and the Serial library to use the pins as UART.
For ptython, java, javascript and C/C++ you can use the MRAA library.
https://github.com/intel-iot-devkit/mraa
http://iotdk.intel.com/docs/master/mraa/
Please post the links of the tutorials you found so we could check them and give you our inputs.
Charlie
ASRIV6
actually i forgot where I found these tutorials, because it was one year back.
Now I am actually exploring my galileo to discover the way to use all ports on-board,
pls can u tell me what is the command to listout all the serial ports (including USB etc all) in linux (galileo), like in windows we have device manager where we can have a list of all devices my machine has, ports, processors etc
this will help me to know howmany serial ports i have on-board and there names
thanks
Community Manager
In Linux, you can find all the devices with the command ls /dev.
You can find all the documentation available for the Galileo board in: https://www-ssl.intel.com/content/www/us/en/do-it-yourself/support/maker/galileo/galileo-documents-a...
If you are planning to use some shields with the board, look at the http://www.intel.com/support/motherboards/desktop/sb/CS-035257.htm Shield Testing Report there are some shields that have been tested so you could see the results of it
Charlie
