Intel® Makers
9873 Discussions
wget: bad address 'iotdk.intel.com'. Unable to connect to internet after setting a static IP to galileo.
AAmar2
After having run the sketch to set the static ip of intel galileo gen2,I am unable to connect it to the internet. It is constantly showing the error-
Here is the screenshot of the error that I am getting after running "opkg update"--
And here is the screenshot of /etc/resolve.conf file after i set the ip to 8.8.8.8. Yet i couldnt connect to internet.
FGTudayatejwani
Community Manager
Hi mishra007,
Thank you for reaching out, while FGT gets in contact with you I would like to give you a hand.
Could you please provide the sketch you're using? Is it one from the Arduino examples?
Are you using a WiFi antenna to have access to the network or are you using an Ethernet cable? Any other information that you think can help us (like the image you're using, etc.) will be more than appreciated.
Also, for future use, I found this really good guide on how to set a static IP on the Galileo http://www.gregorykelleher.com/blog/galileo_ethernet http://www.gregorykelleher.com/blog/galileo_ethernet.
-Pablo
AAmar2
Intel Corporation wrote:
Hi mishra007,
-Pablo
Hi I found a solution on my own with some luck got it working-
It had gateway issue,I mean my default gateway(IP of my router is 192.168.0.1) so I run this following code to get internet access in my intel galileo-
route add default gw 192.168.0.1 eth0.
But instead of running it everytime,I wrote this code in bashrc file and just source it everytime I boot my galileo. This works for now! If there is some other solution then kindly do let me know!
FTinetti
Honored Contributor I
Hi mishra007,
-Pablo
Great, that's why I asked you to send the output of the route command... in the now visible-"approved" (?)-delayed by the moderator post... great you were able to get it to work.
Yes, add that line to the sketch that sets the IP address (after setting the IP address).
Fernando.
FTinetti
FGT udayatejwani
Unfortunately I'm not able to experiment with my Intel Galileo right now, however, there are somethings you can try. Let's focus our work on connecting to the internet.
Please send the output of the commands:
1) In the Windows computer (check you include all the output in your reply):
ipconfig
2) In the Intel Galileo (2 commands, check you include all the outputs in your reply)
ifconfig
route
Take into account you should start your Intel Galileo connected to the router with Internet access, do not start your Intel Galileo withuot your cable connected to the router.
Fernando.
FTinetti
Are you able to see my previous post? I look the warning
"Currently being moderated" so I don't know if you are able to see it...
Fernando.
AAmar2
Fernando.
I couldnt see it earlier,but i can view it now. I saw that same "moderated" warning. I dont know why.
AlHill
There is nothing to be concerned about. Read this thread:
If you have a thread or post in the moderation queue, it will be reviewed by a moderator and either approved or rejected. Most often, approved. However, the forum software has to evaluate each post for potential issues. Bad links and spam have been greatly reduced by examining posts for such issues. The result is clean and safe content for legitimate members of the Intel community.
We appreciate your patience regarding these "moderation" issues. Also, if you see a thread or post with inappropriate content, please report the thread or post so a moderator can examine it.
Doc
FTinetti
I've replied, but my posts get moderated again and again. Send a PM in case you want some help from me (anyway, Intel people know much better).
Fernando.
