Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
what exactly does mraa_gpio_init() do?
Jump to solution
In the MRAA library and the function mraa_gpio_inti() - what exactly is being initialized? What is happening under the covers in both software and hardware?
Community Manager
Hello conor100,
Thank you for interest in the Intel® Edison Breakout Board.
The mraa_gpio_init() function initializes a general purpose Input/Output based on the board number pin (number inside the parenthesis). It helps relate a specific pin from the board to a certain task, via coding.
This link provides the mraa number for each pin of your Edison board: https://iotdk.intel.com/docs/master/mraa/edison.html.
For more detailed information, please check the following links:
https://iotdk.intel.com/docs/master/mraa/gpio_8h.html# a3a9422482a810500cbbe192925574758
https://iotdk.intel.com/docs/master/mraa/classmraa_1_1_gpio.html
For example, this code: https://github.com/intel-iot-devkit/mraa/blob/master/examples/gpio_read6.c, helps the programmer read data form pin 6 (pin J17-7/GP27 of the Edison board) through the mraa_gpio_init(6) function.
I hope you find the previous information useful.
Andres
Community Manager
Hello conor100,
Andres
