Intel® Makers
9872 Discussions
what's the problem about the Edison console
TDeng1
Hello everyone,
I designed my own expansion boar for Edison,and use the "FTDI FT232RQ" to change the UART2 as a console,when power my board and connect the console to my MAC,the address is :
/dev/cu.usbseriail-A504DYI7. I use screen command to get in ,there is nothing ,then I use the Arduino board the address is :
/dev/cu.usbserail-A502P3PQ and I can use the screen to get in. what's wrong? does it means something wrong with my own board?
Diego_V_Intel
Hello Teduav,
I checked the schematic of the Mini-Breakout Board and it seems to be the same as the one in your custom board, so as far as I can see, there are no issues with the connections. I suggest you to check if there is data flowing through the Tx and Rx pins of the FT232RQ to make sure that the USB-to-Serial section is working correctly. A logic analyzer would be great for this test because we would be able to see the signals and check if they are correct or not.
Diego.
Diego_V_Intel
Hello Teduav,
Diego.
TDeng1
Hello,Diego
Thank you for you answer,I find this problem I have connect the TX,RX to another chip without a switch.
