Intel® Makers
9881 Discussions
what's the scope for Echo 2000000?
一秋
One question about Edison PWM setting: echo 2000000 > /sys/class/pwm/pwmchip0/pwm3/duty_cycle, what's the scope for Echo 2000000?
Carlos_M_Intel
Hi Effy,
While using the duty_cycle as 2000000 you will have ~40.64%. In order to calculate the duty cycle you want to use and the number you have to put in
/sys/class/pwm/pwmchip0/pwmX/duty_cycle you need to know that 4950495 is 100%.
You can use the following equivalence:
duty_cycle =
DutyCycle * 4950495
100
Where duty_cycle is the value in /sys/class/pwm/pwmchip0/pwmX/duty_cycle and DutyCycle is the %Duty cycle you want to use. For example if you want to use 40% as DutyCycle you will have as result 1980198.
Charlie
Carlos_M_Intel
Hi Effy,
duty_cycle =
DutyCycle * 4950495
100
Charlie
一秋
Hi Charlie,thanks very much!
