Intel® Makers
9873 Discussions
when i use Intel XDK IoT Edition tool to run the 'on board blink' demo, show the node.js version too low
XZhan33
The version of XDK is iot_web_win_master_3022
And the edison firmware is iot-devkit-prof-dev-image-edison-20160315
All the process are strictly follow the instruction and all steps are working properly.
Is anyone met the same prob. ?
How to solve it ? If need to upgrate the Node.js in edison board, do i need to use MCU kit to do that? Do you have the latest node.js for edison ?
The error info :
Your Node version (v0.10.38) has a partial support of profiler.
The stack frames tree doesn't show all stack frames due to low sampling rate.
The profiling data is incomplete and may show misleading results.
Update Node to v0.11.13 or newer to get full support.
Error: Cannot find module '/opt/xdk-daemon/current/node-inspector-server/node_modules/v8-debug/build/debug/v0.4.6/node-v11-linux-ia32/debug.node
Community Manager
Hello boylitpig,
Could you upload a screenshot of the error message you are receiving. I just tried it and did not see any issues, I'm using the latest image for Edison, which one are you using?
Also, you can get a newer version of node by downloading it from AlexT's repo: http://alextgalileo.altervista.org/edison-package-repo-configuration-instructions.html http://alextgalileo.altervista.org/edison-package-repo-configuration-instructions.html.
Peter.
Community Manager
Hello boylitpig,
Are you still having issues uploading code from the XDK?
Peter.
