Community
cancel
Showing results for
Search instead for
Did you mean:
CChir1
while executing opkg update i am getting these errors
root@galileo:~# opkg update
Downloading http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/base/Packages.gz.
Inflating http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/base/Packages.gz.
Updated list of available packages in /var/lib/opkg/chaos_calmer_base.
Downloading http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/luci/Packages.gz.
Inflating http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/luci/Packages.gz.
Updated list of available packages in /var/lib/opkg/chaos_calmer_luci.
Downloading http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/packages/Packages.gz.
Inflating http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/packages/Packages.gz.
Updated list of available packages in /var/lib/opkg/chaos_calmer_packages.
Downloading http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/routing/Packages.gz.
Inflating http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/routing/Packages.gz.
Updated list of available packages in /var/lib/opkg/chaos_calmer_routing.
Downloading http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/telephony/Packages.gz.
Inflating http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/telephony/Packages.gz.
Updated list of available packages in /var/lib/opkg/chaos_calmer_telephony.
Downloading http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/management/Packages.gz.
Inflating http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/management/Packages.gz.
Updated list of available packages in /var/lib/opkg/chaos_calmer_management.
Downloading http://iotdk.intel.com/repos/3.5/iotdk/galileo/all/Packages.
Updated list of available packages in /var/lib/opkg/iotdk-all.
Downloading http://iotdk.intel.com/repos/3.5/iotdk/galileo/i586/Packages.
Updated list of available packages in /var/lib/opkg/iotdk-i586.
Downloading http://iotdk.intel.com/repos/3.5/iotdk/galileo/quark/Packages.
Updated list of available packages in /var/lib/opkg/iotdk-quark.
Downloading http://iotdk.intel.com/repos/3.5/iotdk/galileo/x86/Packages.
Updated list of available packages in /var/lib/opkg/iotdk-x86.
Downloading http://iotdk.intel.com/repos/20160606/ipk/all/Packages.gz.
wget: server returned error: HTTP/1.1 404 Not Found
Downloading http://iotdk.intel.com/repos//ipk/i586/Packages.gz.
Downloading <a class="jive-link-external-small" href="https://communities.intel.comhttp://iot...
Community Manager
Hi Chichi,
Thanks for your interest in the Intel® Galileo Platform.
We appreciate all the information provided. Regarding the errors you are getting, we have noticed that the repos you are trying to update don't exist, that's why you are receiving "HTTP/1.1 404 Not Found". Could you please share the content of your board's /etc/opkg/ directory as well as the content in the file base-feeds.conf? You can use this command to know it: cat /etc/opkg/base-feeds.conf.
Moreover, you can take a look at the http://alextgalileo.altervista.org/package-repo-configuration-instructions.html AlexT's repo in order to configure your Galileo to fetch packages from his repo and try okpg update again in order to know if you still get any error.
We'll be waiting for your reply.
-Yermi A.
Community Manager
Hi Chichi,
We would like to know if you have any updates or in case you still have the issue, could you please provide the content of your board's /ect/opkg directory as well as the content in the file base-feeds.conf? Remember, we are here to help you.
-Yermi A.
Community Manager
Hi Chichi,
Thanks for the information provided. We have added the repos you shared to our base-feeds.conf file:
root@galileo:~# cat /etc/opkg/base-feeds.conf
src/gz chaos_calmer_base http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/base http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/base
src/gz chaos_calmer_luci http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/luci http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/luci
src/gz chaos_calmer_packages http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/packages http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/packages
src/gz chaos_calmer_routing http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/routing http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/routing
src/gz chaos_calmer_telephony http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/telephony http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/telephony
src/gz chaos_calmer_management http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/management http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/management
For the last one, we added …/packages/management since we were receiving an error from the one you shared. Then, we ran opkg update and we didn't receive any error.
Downloading http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/base/Packages.gz http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/base/Packages.gz.
Inflating http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/base/Packages.gz http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/base/Packages.gz.
Downloading http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/luci/Packages.gz http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/luci/Packages.gz.
Inflating http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/luci/Packages.gz http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/luci/Packages.gz.
Downloading http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/packages/Packages.gz http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/packages/Packages.gz.
Inflating http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/packages/Packages.gz http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/packages/Packages.gz.
Downloading http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/routing/Packages.gz http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/routing/Packages.gz.
Inflating http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/routing/Packages.gz http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/routing/Packages.gz.
Downloading http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/telephony/Packages.gz http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/telephony/Packages.gz.
Inflating http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/telephony/Packages.gz http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/telephony/Packages.gz.
Downloading http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/management/Packages.gz http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/management/Packages.gz.
Inflating http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/management/Packages.gz http://downloads.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/management/Packages.gz.
Downloading http://iotdk.intel.com/repos/3.5/iotdk/galileo/all/Packages http://iotdk.intel.com/repos/3.5/iotdk/galileo/all/Packages.
Downloading http://iotdk.intel.com/repos/3.5/iotdk/galileo/i586/Packages http://iotdk.intel.com/repos/3.5/iotdk/galileo/i586/Packages.
Downloading http://iotdk.intel.com/repos/3.5/iotdk/galileo/quark/Packages http://iotdk.intel.com/repos/3.5/iotdk/galileo/quark/Packages.
Downloading http://iotdk.intel.com/repos/3.5/iotdk/galileo/x86/Packages http://iotdk.intel.com/repos/3.5/iotdk/galileo/x86/Packages.
Downloading http://iotdk.intel.com/repos/3.5/intelgalactic/opkg/i586/Packages http://iotdk.intel.com/repos/3.5/intelgalactic/opkg/i586//Packages.
Updated list of available packages in /var/lib/opkg/mraa-upm.
So, we believe that the error you are receiving could be related to the iotdk.conf file, this is our info:
root@galileo:/etc/opkg# cat iotdk.conf
src iotdk-all http://iotdk.intel.com/repos/3.5/iotdk/galileo/all http://iotdk.intel.com/repos/3.5/iotdk/galileo/all
src iotdk-i586 http://iotdk.intel.com/repos/3.5/iotdk/galileo/i586 http://iotdk.intel.com/repos/3.5/iotdk/galileo/i586
src iotdk-quark http://iotdk.intel.com/repos/3.5/iotdk/galileo/quark http://iotdk.intel.com/repos/3.5/iotdk/galileo/quark
src iotdk-x86 http://iotdk.intel.com/repos/3.5/iotdk/galileo/x86 http://iotdk.intel.com/repos/3.5/iotdk/galileo/x86
Could you please check that you have the same information in the iotdk.conf file? We'll be waiting for your reply, also, if you any question, please let us know.
Have a nice day!
-Yermi A.
CChir1
hello Yermi A,
after the fix you have told me i am getting these errors
wget: server returned ...
CChir1
Thank you for helping my errors for the device is sorted out..
Community Manager
Hi Chichi,
We have noticed that you edited your post, we would like to know if your issues have been solved or you still need assistance.
Have a nice day!
-Yermi A.
CChir1
yes , my issues have been solved for this particular problem thank you!!!
