Python 2.7.3 (default, May 12 2016, 08:33:18)
[GCC 4.9.1] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import nfc
Traceback (most recent call last):
File "", line 1, in
File "/usr/lib/python2.7/site-packages/nfc/__init__.py", line 26, in
from clf import ContactlessFrontend
File "/usr/lib/python2.7/site-packages/nfc/clf/__init__.py", line 35, in
from . import device
File "/usr/lib/python2.7/site-packages/nfc/clf/device.py", line 39, in
from . import transport
File "/usr/lib/python2.7/site-packages/nfc/clf/transport.py", line 32, in
import usb1 as libusb
File "/usr/lib/python2.7/site-packages/usb1/__init__.py", line 61, in
from . import libusb1
File "/usr/lib/python2.7/site-packages/usb1/libusb1.py", line 199, in
libusb = _loadLibrary()
File "/usr/lib/python2.7/site-packages/usb1/libusb1.py", line 173, in _loadLibrary
return dll_loader('libusb-1.0' + suffix, **loader_kw)
File "/usr/lib/python2.7/ctypes/__init__.py", line 365, in __init__
self._handle = _dlopen(self._name, mode)
OSError: libusb-1.0.so: cannot open shared object file: No such file or directory
Hello ChiChi,
Thanks for reaching out!
I tested it and got the same error messages as you. It seems that it is simply a dependency issue. These are the steps I took to fix it:
pip install -U nfcpy
pip install clf
pip install pyusb
opkg update
opkg install libusb-1.0-0 libusb-1.0-dbg libusb-1.0-dev libusb-0.1-staticdev
After doing this I imported the nfc library and no errors were shown.
I hope this information helps you,
Pedro M.
Hello ChiChi,
pip install clf
pip install pyusb
opkg update
Pedro M.
Hello pedro,
while going for pip install clf i am getting these error for no space left on device but i have lot's of space in it..
Downloading/unpacking requests>=2.3.0 (from clf)
Downloading requests-2.13.0.tar.gz (557kB): 557kB downloaded
Running setup.py egg_info for package requests
warning: no files found matching 'test_requests.py'
warning: no files found matching 'requirements.txt'
Installing collected packages: clf, Pygments, docopt, requests
Running setup.py install for clf
error: could not create '/usr/lib/python2.7/site-packages/clf': No space left on device
Complete output from command /usr/bin/python -c "import setuptools;__file__='/tmp/pip-build-root/clf/setup.py';exec(compile(open(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-ORHTfd-record/install-record.txt --single-version-externally-managed:
running install
running build
running build_py
creating build
creating build/lib
creating build/lib/clf
copying clf/exceptions.py -> build/lib/clf
copying clf/__init__.py -> build/lib/clf
copying clf/constants.py -> build/lib/clf
copying clf/command.py -> build/lib/clf
copying clf/api.py -> build/lib/clf
running egg_info
writing requirements to clf.egg-info/requires.txt
writing clf.egg-info/PKG-INFO
writing top-level names to clf.egg-info/top_level.txt
writing dependency_links to clf.egg-info/dependency_links.txt
writing entry points to clf.egg-info/entry_points.txt
warning: manifest_maker: standard file '-c' not found
reading manifest file 'clf.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
writing manifest file 'clf.egg-info/SOURCES.txt'
running install_lib
creating /usr/lib/python2.7/site-packages/clf
Command /usr/bin/python -c "import setuptools;__file__='/tmp/pip-build-root/clf/setup.py';exec(compile(open(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-ORHTfd-record/install-record.txt --single-version-externally-managed failed with error code 1 in /tmp/pip-build-root/clf
Storing complete log in /home/root/.pip/pip.log
File "/usr/bin/pip", line 9, in
load_entry_point('pip==1.3.1', 'console_scripts', 'pip')()
File "/usr/lib/python2.7/site-packages/pip/__init__.py", line 149, in main
return command.main(args[1:], options)
File "/usr/lib/python2.7/site-packages/pip/basecommand.py", line 182, in main
log_fp.write(text)
IOError: [Errno 28] No space left on device
hello pedro,
after carefully doing above steps i am getting a new error
>>> import nfc
File "", line 1, in
OSError: /lib/libusb-1.0.so: file too short
please ignore the post which i had posted about second command error..
All the commands which were stated above with pip and opkg were executed syccessfully..
Hi ChiChi,
I'm confused, do you still need help? Or, did my previous suggestion helped?
The error messages you received simply let you know that your board's memory was full, so, packages were not able to be installed. If you are still receiving that error message, I suggest you to flash your SD with a fresh image and try again.
Let me know.
Pedro M.
Hello pedro,
Commands you told me worked and packages got installed successfully but I am getting a new error while importing NFC that is file is too short ..
>>> import nfc
File "", line 1, in
Hello ChiChi,
I find that issue very strange, I just reflashed my SD with a fresh image (I'm using the latest image iot-devkit-prof-dev-image-galileo-20160525) and tried installing the packages again and I was able to import the nfc library without trouble.
Have you tried reflashing your image?
Let me know.
Pedro M.
