Community
cancel
Showing results for
Search instead for
Did you mean:
rmavr
wifi driver
Install Win10 IoT on STK1A32SC.
Install latest drivers for WiFi. They show up in the control panel, but any attempt to configure WiFi results in an exception "explore.exe" alert box "OK".
How does one get WiFi configured?
n_scott_pearson
Super User Retired Employee
How did you install the driver? Did you over-install a previous version? This can be problematic. I suggest that you uninstall the existing driver, reboot and then install the latest driver (again). Since the Bluetooth capability is provided by the same piece of hardware, I would recommend that you include Bluetooth in the same process. That is, uninstall both the Wireless and Bluetooth drivers, reboot and then install the latest Wireless and Bluetooth driver packages (again).
Hope this helps,
Community Manager
Hello RMavro,
Was you system working fine before or this is an issue that you have since you purchase the unit?
Is there any exclamation mark in the device manager or it shows correctly installed? If there is an exclamation mark in device manager, I suggest you to follow N. Scott Pearson recommendation.
Ivan
rmavr
Working fine before? The product comes with no installed OS so there is no "before".
We load the Win10 IoT (OEM) OS.
This turns out to be an issue with Intel hardware and compatible Intel drivers.
We were using Win10IoT 64-bit. The .current version (19) drivers simply don't work and produce the weird error.
We loaded the Win10IoT 32-bit version and the issue is resolved.
Community Manager
I'm glad that your issue has been resolved and thank you for taking your time to let us know.
Best wishes,
Ivan.
rmavr
I guess the question remains: is there a WiFi driver for 64-bit Win 10 IoT that works?
Not urgent as we will simply use 32-bit.
Community Manager
The one available is at the following link:
https://downloadcenter.intel.com/download/26326/Intel-Wireless-Technology-Based-Driver-for-Intel-Com... https://downloadcenter.intel.com/download/26326/Intel-Wireless-Technology-Based-Driver-for-Intel-Com...
It is available for Windows® 10, 64-bit* and Windows® 10 IoT Enterprise*
Ivan.
rmavr
Hi Ivan,
Yes, we know about that driver. It is the one that does not work for 64-bit but does work for 32 bit.
n_scott_pearson
Have you tried using an older version? This may be a bug in (just) the latest version...
Community Manager
Let me try this driver with one of the units we have in our Lab to see if we get the same behavior.
Ivan.
Community Manager
Hello RMavro,
At this point, I suggest you to wait for a new version to come up that hopefully it will work for you.
Best wishes,
Ivan.
Community Manager
We finally were able to test this.
What we support is Windows 10 IoT Enterprise. As seen on this page: https://www.microsoft.com/en-us/WindowsForBusiness/windows-iot https://www.microsoft.com/en-us/WindowsForBusiness/windows-iot, "Note that Windows 10 IoT Mobile is a binary equivalent to Windows 10 Mobile Enterprise".
I installed Windows 10 Enterprise x64 and was able to get the WIFI to work.
Ivan.
