Did you make any previous Wyliodrin related configuration? I also use that version and have configured WiFi multiple times and that log has never appeared. Does that log ever stops to allow terminal access? If you re-flash the image and run configure_edison –setup do you see the same log?
Sergio
I didn't make any Wyliodrin related configuration.
after i re-flash the image, i run configure_edison --setup.
the log doesn't appeared
when i run configure_edison --wifi, some edisons are ok.
but the others doesn't work
when i flashed , the log never appeared.
Do you see this behavior in the latest image? Release 3.0 can be downloaded here https://software.intel.com/en-us/iot/hardware/edison/downloads https://software.intel.com/en-us/iot/hardware/edison/downloads .
You can see instruction to flash the latest image here https://software.intel.com/en-us/articles/flash-tool-lite-user-manual https://software.intel.com/en-us/articles/flash-tool-lite-user-manual
Sergio
Hi kevintocol,
Were you able to flash to the latest image to see if the issue persists?
Sergio
I already flashed the latest version image.
however, when i run configure_edison --wifi, the log appeared as ever.
I'm unable to reproduce this issue. I too flashed to the latest image and run configure_edison –wifi and after the "Please connect your laptop of PC to the same network as this device" message I'm able to use the terminal.
Do you see the same results if you flash using the flashall script /docs/DOC-25154 https://communities.intel.com/docs/DOC-25154 ?
Sergio
I think automatic scripting configuration at boot-up was conflict with the latest image
http://stephaniemoyerman.com/?p=41 Automatic Scripting at Boot-Up | Musings from Stephanie
when i not configured automatic scripting, the log didn't appeared
That may be possible, with a fresh image flashed this issue doesn't occur. Does this workaround allow you to work with your Edison?
Sergio
