Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
yocto build (base/full) images update failed in intel joule board
Jump to solution
Hi All,
I have intel joule 570x module, I have setup yocto build taken fromhttps://github.com/01org/ref-os-iot GitHub - 01org/ref-os-iot: This is the official distribution of the Intel(R) Reference Operating System for the Internet…
With this commit able to get base-image and full-image for intel joule board
commit 1d2a875aafaf3492d3971c459b7fe5b5cf796314
Author: Ravindran, Arun intel.com>
Date: Fri Apr 7 15:25:21 2017 +0300
ref-os-iot: Enable SDK support
Signed-off-by: Ravindran, Arun intel.com>
Reviewed-by: Kalugin, Evgeny intel.com>
Programming guide
By following the https://developer.ubuntu.com/core/get-started/intel-joule# Installation%20instructions https://developer.ubuntu.com/core/get-started/intel-joule# Installation%20instructions. i have tried to update the base firmware/Full firmware into the board
xzcat /media/ubuntu//full-image-intel-5xx-64-20170602060648.wic.xz | sudo dd of=/dev/mmcblk0 bs=32M status=progress; sync
on reboot i am getting the attached error(yocto_fullimage_Installation_failed_full-image-intel-5xx-64-20170602060648.wic.xz.txt, yocto_baseimage_Installation_failed_base-image-intel-5xx-64-20170531132501.wic.xz.txt). Guide us to overcome the error
Thanks and regards,
Ananth
Community Manager
Hi Ananth,
Thanks for your interest in the Intel Joule platform.
According to this link: https://developer.ubuntu.com/core/get-started/intel-joule# Installation%20instructions Intel Joule - Ubuntu you are trying to update your Ref-OS-IoT image following the instructions to install Intel Joule Ubuntu Core on the Joule.
We would like to suggest you that once you have built the Ref-OS-IoT image successfully (following that guide: https://github.com/01org/ref-os-iot https://github.com/01org/ref-os-iot) try to install the image on the Joule board following these instructions: https://software.intel.com/en-us/node/721477 Online Guide for the Intel® Joule™ Module.
Let us know if this information helps.
-Yermi A.
Community Manager
Hi Ananth,
-Yermi A.
Community Manager
Hi Ananth,
Do you have any updates? Were you able to install the Joule's image?
-Yermi A.
Community Manager
Hi Yermi A,
Thanks for you support !
I was mistaken in using full/base-image-intel-*.wic.xz, Since the image itself a self extracting live image.
i programmed the image directly in the internal mmc of Intel joule, instead of a secondary storage. After following your mentioned link, i was able to flash the intel joule board successfully.
Thanks and regards,
Ananth
