Community
cancel
Showing results for
Search instead for
Did you mean:
SR11
yocto custom image - libgdiplus recipe failing
Jump to solution
In meta-mono recipes,
IMAGE_INSTALL += "mono"
IMAGE_INSTALL += "mono-xsp"
are getting successfully added to the linux image.
However, when I do IMAGE_INSTALL += "libgdiplus", I'm getting below errors:
Loading cache: 100% |# | ETA: 00:00:00
Loaded 1417 entries from dependency cache.
Parsing recipes: 100% |# | Time: 00:00:02
Parsing of 1011 .bb files complete (1008 cached, 3 parsed). 1418 targets, 117 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
ERROR: Nothing PROVIDES 'libxft' (but /mnt/edison-src/meta-intel-edison/meta-mono/recipes-mono/libgdiplus/libgdiplus_2.10.8.bb DEPENDS on or otherwise requires it)
ERROR: libxft was skipped: missing required distro feature 'x11' (not in DISTRO_FEATURES)
NOTE: Runtime target 'libgdiplus' is unbuildable, removing...
Missing or unbuildable dependency chain was: ['libgdiplus', 'libxft']
ERROR: Required build target 'edison-image' has no buildable providers.
Missing or unbuildable dependency chain was: ['edison-image', 'libgdiplus', 'libxft']
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
System.Data.SQLite is internally referencing System.Drawing which inturn is looking for libgdiplus.
Is there any way to add libgdiplus to yocto image?
Srikanth
Pablo_M_Intel
Hi Blackhole,
If you look in the AlexT repository http://repo.opkg.net/edison/repo/core2-32/ http://repo.opkg.net/edison/repo/core2-32/, there you can find the libgdiplus package available. You´ll just need to configure your base-feeds.conf file to fetch packages from the repo (in case you haven't already) or download it directly using the full link.
Pablo
Pablo_M_Intel
Hi Blackhole,
Pablo
SR11
Hi Pablo,
Thanks for your reply.
Let me try and see whether it works without any version conflicts with mono.
Meanwhile is it possible to add these .ipk packages directly to image?
Srikanth
