DLLEXPORT
stydofe1
I had the following errors when parallelizingsome codes in IVF 12,
error #8117: DLLIMPORT and DLLEXPORT symbols may not be specified in a COPYIN or REDUCTION list.
It seems that copyin does not work for a threadprivate variable, how should the variable be initialized?
Thanks in advance.
stydofe1
With IVF12, Can a module variable with dllexport or dllimport attribute be a threadprivate varaible, I tiried this without success. Is it a compiler problem? Thanks.
