Does Dotnet Applications run on Mac Os
Priyadhars_K_Intel
HI , i would like to develop an application in dot net to enable on Multicore and slo run the application on Mac OS. Is it possinble?Please suggest ASAP
TimP
The method for running Microsoft CLR applications across platforms would be under Mono, so you would have to investigate whether you can run that on your desired platforms.
gaston-hillar
Valued Contributor I
Quoting - tim18
Priya, tim18,
Mono apps do run on MAC OS X. You have to check for compatibility and limitations.
Cheers,
Gaston
Priyadhars_K_Intel
Thank you tim!
Priyadhars_K_Intel
thank you Gaston
mahmoudgalal1985
Quoting - tim18
Thank you.
mahmoudgalal1985
Quoting - Gastn C. Hillar
Priya, tim18,
Cheers,
Gaston
Thank you
