1707 Discussions
How to make a general return from the code without stop
Mykola_M_
Hallo all experts,
for my code written in fortran also the web-service is developed. The problem is that any stop-command (if error appears) kills the web-service. What I need now is to replace all my "stops" by the fortran-command which makes exit (say, with flag), but not terminates the head-subroutine. I believe that the command like that is already exists. Otherwise, I'm forced to write the set of the commands for returning to the head-subroutine. The point of such return is not clear.
With thanks,
Mykola.
jimdempseyatthecove
Is your application multi-threaded?
Does your code reside in a DLL (or shared library)?
The cleanest way is for all (most) of your subroutines and functions return a status. You define the status values, and then if any CALL/function returns an error status, you propagate it up the returns.
Lahey has a Fortran for .NET that supports: try/catch/finally/throw
Modifying your code for that, is on the order of modifying your code to pass a STATUS variable.
Jim Dempsey
jimdempseyatthecove
Jim Dempsey
