Max number of openmp locks?
James_Benze
Is it possible that there are a maximum number of openmp locks one can allocate? I'm using ifort 11.1, and after a large amount of lock allocations, omp_init_lock() starts returning 0s.
So does this mean that I'm some how "out of locks"?
EDIT: Also, I can't seem to replicate this on trivial test case. Any other reason omp_init_lock() would return 0?
SergeyKostrov
Valued Contributor II
Hi James,
Quoting James Benze
[SergeyK] I just checked an OpenMP v3.1 Specifications and I haven't found any referencesrelated to a
maximum number of locks.
Please take a look at a chapter 3.3 Lock Routings andexample A.43 on a page 292.
In the example an array of locks (1000 in total) is initialized.
[SergeyK] I'm not sure. Would you be able to provide more technical details?
EDIT: Also, I can't seem to replicate this on trivial test case.Any other reason omp_init_lock() would return 0?
[SergeyK] It cannot return 0 because 'omp_init_lock' functiondoesn't return anything. It is declared as follows:
void omp_init_lock( omp_lock_t *lock );
Sergey
pbkenned1
Are you using ALLOCATE() to obtain your OpenMP locks? The underlying lock representation is based on the INTEGER KIND that will hold an address, ie, the return value of intrinsic function INT_PTR_KIND(). The result is 4 bytes on IA-32 architecture, or8 bytes on Intel 64 architecture.
So if you're using ALLOCATE(), the maximum number of OpenMP locks you can obtain is limited by the largest chuck of heap you can successfully allocate. We've tested up to 5 million locks in a single program!
You could declare your array of OpenMP locks:
integer (kind=omp_lock_kind), allocatable :: omp_locks(:)
Then check the status return value for any error:
allocate (omp_locks(num_in_block), stat=alloc_err)
Completeexample:
program omp_lock_alloc
use omp_lib_kinds
integer alloc_err
integer, parameter :: num_in_block =256
if(alloc_err .EQ. 0) then
print *,'allocated ',num_in_block,' omp locks'
else
print *,' failed to allocate omp locks'
endif
end program omp_lock_alloc
>ifort -Qopenmp omp_lock_alloc.f90
Intel Visual Fortran Intel 64 Compiler XE for applications running on Intel 64, Version 12.1.4.325 Build 20120410
Copyright (C) 1985-2012 Intel Corporation. All rights reserved.
Microsoft Incremental Linker Version 10.00.30319.01
Copyright (C) Microsoft Corporation. All rights reserved.
-out:omp_lock_alloc.exe
>omp_lock_alloc.exe
allocated 256 omp locks
Patrick Kennedy
Intel Developer Support
Vladimir_P_1234567890
Hello James,
Did you check a memory consumption? The one of the reason to 'out-of-locks' might be out of memory for your app.
--Vladimir
