Threadpool 1.14 ...
aminer10
Hello all,
I think we don't need an array of critical sections...
You can download the new version 1.14 of both
Threadpool and Threadpool with priority from:
http://pages.videotron.com/aminer/
I have included a test_thread.pas example
- with many workers threads ...- .
This patch avoids deadlock...
TPThreadPool.execute() method have changed to...
function TThreadPool.execute(func:TmyProc;const Context: Pointer): Boolean;
var
params: MyParam;
local_balance,local_count:integer;
begin
params:=MYParam.create;
params.proc:=func;
params.param:=context;
local_balance:=LockedIncLong(balance1) mod FThreadCount;
local_count:=Queues[local_balance].count;
while not Queues[local_balance].push(TObject(params)) do;
if local_count=0 then events[local_balance].setevent;
end;
Thank you for your time...
Sincerely,
Amine Moulay Ramdane.
aminer10
Threadpool is very easy to use...
Here is an example with priorities - you can
giveLOW_PRIORITY, NORMAL_PRIORITY
and HIGH_PRIORITY - look attest_thread.pas
inside the pthreadpool.zip - that i have just wrote
for you, that use many workers threads..
Note: don't forget to give some feedback...
program test;
uses
{$IFDEF Delphi}
cmem,
{$ENDIF}
PThreadPool,sysutils,windows,classes,syncobjs;
type
TMyThread = class (TPThreadPoolThread)
//procedure ProcessRequest(obj: Pointer); override;
procedure MyProc1(obj: Pointer);
procedure MyProc2(obj: Pointer);
end;
var hndlArr : Array[0..19] of THandle;
AId:DWORD;
event1,event2:TSimpleEvent;
n:int64;
j:integer;
myobj:TMyThread;
TP: TPThreadPool;
obj:pointer;
cs:TCriticalSection;
number:integer;
procedure TMyThread.MyProc1(obj: Pointer);
begin
cs.enter;
inc(number);
if number=8000 then event2.setevent;
//writeln('This is MyProc1 with parameter: ',integer(obj));
cs.leave;
end;
procedure TMyThread.MyProc2(obj: Pointer);
begin
cs.enter;
inc(number);
//writeln('This is MyProc2 with parameter: ',integer(obj));
cs.leave;
end;
function StartFunc1(InVal:pointer):DWORD;
var temp:tobject;
i:integer;
obj:pointer;
begin
event1.waitfor(INFINITE);
for i:=0 to 1999
do
begin
obj:=pointer(i);
TP.execute(myobj.myproc1,obj,NORMAL_PRIORITY);
end;
end;
function StartFunc2(InVal:pointer):DWORD;
var temp:tobject;
i:integer;
obj:pointer;
begin
for i:=0 to 1999
do
begin
obj:=pointer(i);
end;
end;
function StartFunc3(InVal:pointer):DWORD;
var temp:tobject;
i:integer;
obj:pointer;
begin
for i:=0 to 1999
do
begin
obj:=pointer(i);
TP.execute(myobj.myproc2,pointer(obj),NORMAL_PRIORITY);
end;
end;
function StartFunc4(InVal:pointer):DWORD;
var temp:tobject;
i:integer;
obj:pointer;
begin
for i:=0 to 1999
do
begin
obj:=pointer(i);
end;
end;
begin
number:=0;
cs:=TCriticalSection.create;
myobj:=TMyThread.create;
TP := TPThreadPool.Create(4, 20, TMyThread); // 4 workers threads and 2^20 items for each queue.
event1:=TSimpleEvent.create;
event2:=TSimpleEvent.create;
hndlArr[0]:=BeginThread(nil,0,@StartFunc1,pointer(1),0,AId);
hndlArr[1]:=BeginThread(nil,0,@StartFunc2,pointer(1),0,AId);
hndlArr[2]:=BeginThread(nil,0,@StartFunc3,pointer(1),0,AId);
hndlArr[3]:=BeginThread(nil,0,@StartFunc4,pointer(1),0,AId);
event1.setevent;
WaitForMultipleObjects(4, @hndlArr, True, INFINITE);
event2.waitfor(INFINITE);
writeln('Number is: ',number);
end.
Sincerely,
