Using DLL in MDI project
moncef
Iam using CVF to built an MDI project and I have a problem to call a Dialog Box written in a DLL wich is a subproject of the main project.
The source code of the DLL called BurnersClass.dll is :
integer*4 function ComponentBurner(BurnerTyp,GlobalIcon)
!DEC$ ATTRIBUTES STDCALL, REFERENCE,ALIAS :"ComponentBurner":: ComponentBurner
!DEC$ ATTRIBUTES DLLEXPORT::ComponentBurner
include 'resource.fd'
integer BurnerTyp
integer GlobalIcon
BurnerMenu%handle=CreateDialogParam(HandleAndInstance%ghInstance,IDD_Component_Tab, &
MDI_WINDOW_Current%Handle, loc(BurnerTab),0)
ComponentBurner=0
return
end function ComponentBurner
integer*4 function BurnerTab( hDlg,message,uParam,lParam )
!DEC$ ATTRIBUTES STDCALL, REFERENCE,ALIAS :"BurnerTab":: BurnerTab
!DEC$ ATTRIBUTES DLLEXPORT::BurnerTab
use user32
use kernel32
implicit none
include "Resource.fd"
integer hDlg
integer message
integer uparam,lparam
type (T_NMHDR) itabmessage
select case(message)
case( WM_INITDIALOG)
BurnerTab=1
return
case (WM_COMMAND)
select case (LOWORD(uParam))
case (IDOK,ID_ESCAPE)
end select
case(WM_move)
return
end select
BurnerTab=0
return
end function BurnerTab
The source code of the main program part that used this dll is :
integer*4 function BurnersPreprocessing(BurnerTyp)
!DEC$ IF DEFINED(_X86_)
!DEC$ ATTRIBUTES STDcall, ALIAS : '_BurnersPreprocessing@16' :: BurnersPreprocessing
!DEC$ ELSE
!DEC$ ATTRIBUTES STDcall, ALIAS : 'BurnersPreprocessing' :: BurnersPreprocessing
!DEC$ ENDIF
use user32
use kernel32
use comctl32
use DFWIN
use THESSGlobals
use HeatLibDrawingVar
use MDI_WindowsVar
use FuelClass
implicit none
integer iret
integer BurnerTyp
logical bret
integer(HANDLE) dll_handle(2)
integer(BOOL) free_status
pointer(p_ComponentBurner, ComponentBurner)
interface
!DEC$ ATTRIBUTES DLLIMPORT::ComponentBurner
integer BurnerTyp
integer GlobalIcon
end interface
dll_handle(1) = LoadLibrary ("BurnersClass.dll"C)
if (dll_handle(1) == NULL) then
! Failure
stop
end if
p_ComponentBurner = GetProcAddress (dll_handle(1), "ComponentBurner"C)
if (p_ComponentBurner == NULL) then
! Failure
stop
end if
iret = ComponentBurner(BurnerTyp,GlobalIcon,IDD_component_tab)
BurnersPreprocessing=0
return
end function BurnersPreprocessing
When I debug the main program and I execute the line code :
I receive the message : Unhandelded exception in Main.exe (called BurnersClass.dll):0x000005:Acces Violation.
And inside the DLL when I check the values of the function BurnerTab arguments : hDlg message, uParam, lParam I obtains :
hDlg = Undefined Adress
message = Undefined Adress
uParam = Undefined Adress
lParam = Undefined Adress
If you have a solution, or a simple example of using DLL with MDI project send it me
thanks in advance
TimP
This would be topical only on the Windows Fortran forum.
