What is "deadlock-safe"?
ClayB
I received an announcement in my email for Message-Driven Java Threads API this morning. Apparently, Java threads can send and receive message between themselves with this API.
Perusing the few paragraphs of the announcement I came across the term "deadlock-safe" which I didn't understand. I know what "deadlock-free" would imply. Since I'm unfamiliar with Java Threads and may not be up-to-date on the most current lingo in that area, I went to the proffered website and still didn't find anything.
Can anyone give me a definition/description of "deadlock-safe"? How is this important to Java Threads, especially for those that can pass messages? Examples would help this old, tired brain grasp any new-fangled concepts.
-- clay
Intel_C_Intel
> understand.
Lock-free is deadlock-free. Java is using some lock-free algos. RCU... They have classes for atomic primitives that can implement many lock-free algos.
If a piece of code is holding a complex set of locks, and calls an API which uses its own locking schema... Sometimes you can deadlock yourself. I think there is a link on MSDN somewhere about this issue.
This is an example of a lock & deadlock-free algo
Message Edited by intel.software.network.support on 12-09-2005 01:41 PM
Intel_C_Intel
> I'll buy the lock-free is deadlock-free. I assume
> that you can get rid of one or more of the conditions
> for deadlock by doing this?
Yep.
> If the Java primitives do use
> lock-free methods to achieve a deadlock-free
> implementation
Java uses lock-free algos in it new dictionary:
Java Runtime Improvements
And its event multi-caster. Maybe RCU?
> For example, two
> threads both execute a blocking receive expecting the
> other thread to do the send operation first.
INFINITE blocking will deadlock for sure, if your not safe.
> Does the Java thread message passing API
> implementation not have blocking operations?
Not sure. I don't use Java.
> Perhaps
> each operation is timed and this could break the
> deadlock cycle.
That would do it.
P.S.
Is this similar to the message you got?
Deadlock Safe Java API?
ClayB
> P.S.
Yes, that is the product I was sent information about.
I don't use Java, either, so I'm not sure about some of the Java specific questions I posed. (I think we had one admitted Java Threads user in the Forum at one time. I was hoping they could have given some insights.)
--clay
