XP KRNL386.EXE crashed under Hyper-Threading.
rybakov_anton
Hi All.
I develop one 16-bit application, which runs under WinXP. Without HT it works fine, but if i enable Hyper-Threading or run it on 2-processor machine, my app crashed with following sytem error message:
"Application Error"
MyApp caused a General Protection Fault
in module KRNL386.EXE at 0001:B5DB
By the way, it happend only after longtime work (ussuallyapp works twenty-four hours a day), and not depends on user's actions.
Any ideas, how to understand this problem ?
Previously thanks....
ClayB
Anton -
Can you provide more details on your application? For instance, is it threaded? How was it built? Compiler used, libraries called, system routines accessed? What kinds of computation does it do (without user intervention)?What processors have you run this on?
-- clay
rybakov_anton
Yes, of course.
No, it's 16-bit app for Windows. So, it can't be multithreaded....
It works in one timer procedure.
My app build under Borland C++ 4.5 (very old project, but i must maintain it). It works with our own drivers (own soundcards)and also use 16-bit to 32-bit thunk mechanism.
Basically, appgets sound stream (telephone talks) from our sound cards, processing it (some sound filters) and store to own DB.
For example, on
Intel Pentium 4HT, 2800 MHz (3.5 x 800) Northwood HyperThreading
CPU params: x86 Family 15 Model 2 Stepping 9 GenuineIntel ~2806 ???
